♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
#4076
Re: (-NA-aLL-thE-wAy-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -NA-aLL-thE-wAy- »</TD></TR><TR><TD CLASS="quote"> I might take a vacation day from work and spend it blasting all day. </TD></TR></TABLE>
I took a sick day once to go to a junkyard to get a part I needed! Let's see some pics of your media blasting.
#4077
EFSS153
Re: (civicandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy »</TD></TR><TR><TD CLASS="quote">
I took a sick day once to go to a junkyard to get a part I needed! Let's see some pics of your media blasting. </TD></TR></TABLE>
I hope it stops raining in the next 5 hours, otherwise I won't be able to do it today.
#4079
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -NA-aLL-thE-wAy- »</TD></TR><TR><TD CLASS="quote">Is there a specific brand of sand paper you all use? I'm getting closer to needing to buy some.</TD></TR></TABLE>
I tried alot of different kinds and my favorite was actually this 80 grit stuff from home depot. (to sand filler down) It kept its grit the longest. Its like whiteish with blueish dots somewhat.
After u get it shaped you sand it with 320 so theres no sanding scratches. I liked the home depot stuff best again.
Then for wetsanding primer i used 3m jobpack 600grit and it worked good. Then wetsanding the clear i used 1600 and 2000 3m jobpack.
#4080
Re: (EF8kid)
Does anyone know where i can get replacement OEM(or same quality) of the most common bolts on our cars.. the 10MM head w/ m8X 1.25 ( ithink thats it).. theyre like 1/2" long
on nearly everything
#4082
Re: (DarkBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 »</TD></TR><TR><TD CLASS="quote">Does anyone know where i can get replacement OEM(or same quality) of the most common bolts on our cars.. the 10MM head w/ m8X 1.25 ( ithink thats it).. theyre like 1/2" long on nearly everything</TD></TR></TABLE>
for the dealer...if money is not an option
there are also specialty nut and bolt websites that sell them on the internet
#4084
Re: (AnToNy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnToNy »</TD></TR><TR><TD CLASS="quote">
similar boats
where can i order those bolts online asap!
similar boats
#4087
Re: (DarkBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 »</TD></TR><TR><TD CLASS="quote">Where can i order those bolts online?</TD></TR></TABLE>
http://www.hondaautomotivepart...cgry5=
#4088
Re: (AnToNy)
is the brake line in that bottom hole or top, tryin to figure out which hole to fill. thanks
#4090
1 Post
Re: (h22apwrdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22apwrdcivic »</TD></TR><TR><TD CLASS="quote">is the brake line in that bottom hole or top, tryin to figure out which hole to fill. thanks</TD></TR></TABLE>
Bottom hole
Bottom hole
#4093
Re: (PandaHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaHatch »</TD></TR><TR><TD CLASS="quote">I pay like $0.09 each for the bolts, they're cheap and make a world of difference. </TD></TR></TABLE>
where do you get your bolts?
#4100
EFSS153
Re: - Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion - (-NA-aLL-thE-wAy-)
Added to page 1 for others to use. \/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid »</TD></TR><TR><TD CLASS="quote">
Q: Is there a specific brand of sand paper you all use? I'm getting closer to needing to buy some.
A: I tried alot of different kinds and my favorite was actually this 80 grit stuff from home depot. (to sand filler down) It kept its grit the longest. Its like whiteish with blueish dots somewhat.
Then for wetsanding primer i used 3m jobpack 600grit and it worked good. Then wetsanding the clear i used 1600 and 2000 3m jobpack. </TD></TR></TABLE>
If someone wants to sum up the bolt info I'll add it to page one, I'm too tired to right now.
