shaved emblems
Old Jun 11, 2002 | 05:44 PM
mafioso102's Avatar
New User
Default shaved emblems
i want to shave my emblems, what is best to fill the holes with? in addition, what type of sandpaper would you recommend?
Old Jun 11, 2002 | 06:55 PM
gribbs's Avatar
Default Re: shaved emblems (mafioso102)
THats a job for a body shop man,
youll need body filler and then repaint
you cant paint just a section of a hood or trunk, those parts are the easiest to spot flaws on
so.......wait till your gettin the whole car painted....for now, paint your emblems black or gunmetal (if mine werent shaved I would do that )
Old Jun 11, 2002 | 07:47 PM
threatcon13's Avatar
New User
Default Re: shaved emblems (gribbsEG8)
yes its best done by a bodyshop but he probably cant afford to repaint at the whole moment...i would just do a poor man's job. for me, i juss took off the emblem and left two holes (where it said acura) ..doesnt bother me that much...just waitin to get it to a bodyshop.
Old Jun 11, 2002 | 07:49 PM
NiiS's Avatar
i lost both my emblems to thieves...instead of replacing them, i simply went to a sticker shop and color-matched a few square inches of sticker. i cut tiny circles and placed them accordingly. cheap, effective, and nobody will know...just my experience.
Old Jun 11, 2002 | 08:06 PM
satintegra's Avatar
Default Re: shaved emblems (sinister)
i saw a teg that plugged in one of those license plugs into the rear emblems holes before. it looks kinda weird but i guess it does its job.
Old Jun 12, 2002 | 05:37 AM
mafioso102's Avatar
New User
im getting the car painted in a couple weeks, but why pay a body shop when I can do it myself. Isn't that the point of this site. Thats like me going to the hybrid section, asking how to swap an engine, and them telling me to take it to a performance shop! Can anyone w/experience with this help me out?
Old Jun 12, 2002 | 05:46 AM
Grimm's Avatar
bondo
fill
smooth
dry
sand
paint
Old Jun 12, 2002 | 07:10 AM
mafioso102's Avatar
New User
Default Re: shaved emblems (Grimm)
bondo
fill
smooth
dry
sand
paint
thanks! i was just unsure of using bondo on a hood b/c i heard it wasnt too good.
Old Jun 12, 2002 | 08:00 AM
Grimm's Avatar
it's not after a while like a year or so it will crack but it's cheaper than having someone fill it with sheet metal or fill it with liquid metal and sand/buff down the edges so it's factory smooth then paint it?
Old Jun 12, 2002 | 12:09 PM
slomofo's Avatar
GDD Member
I had like 10 emblems in the glove box of my integra. When I ran out of emblems from getting jacked, I shaved them using bondo. Get something to cover the holes on the inside, and then use bondo on the outside, or else the bondo will just fall through the hole and it'll waste your money.
Old Jun 12, 2002 | 12:31 PM
uNF$@#!'s Avatar
Default Re: shaved emblems (slomofo)
you dont bondo holes
thats sheer stupidity as the bondo will crack and fall out.
to do it right, you will need someone to weld the holes shut.
Old Jun 12, 2002 | 04:11 PM
ImportHatch's Avatar
Default Re: shaved emblems (00-0187)
Ok, you cant bondo over a hole that has no backing on it. You could weld on the backside of the holes then bondo the face. Or you could fiberglass over the backside (using the mesh) then bondo the outside. Either way you do it, you have to have a backing on it or it will just fall out after time. Hope that helps a little.....
Yager-
UnoPuntoCinco
Paint and Body
May 31, 2007 04:20 AM
accord450
Aug 5, 2004 07:08 PM
hsilva
Jun 10, 2003 10:06 PM
Rob!
Apr 28, 2002 11:25 AM
96tegsr
Oct 25, 2001 09:51 PM
