pcv problems plz help
hey guys just got my y8 re ringed and the car is still smoking, so i figured i would change the pcv valve. I look and there is no black box and no valve. looks like somone has put a ruber freeze plug in there to plug the hole. My question is what should i do to get that to vent agian its is a hard spot to work so if someone has had same problem and could help me out on what they did it sure would help i think this could be some of the problem while car is smoking and i am not wanting to drive it with not venting right and i am running 8 psi of boost someone plz help me fix this problem
this belongs in one of the tech forums. either the Forced Induction forum (because you're running boost) or the 92-00 civic forum. you'll get a lot more help there than in the appearence forum.
N1civicSi
Sep 13, 2007 06:52 AM
