oxidation??
Old Jun 27, 2004 | 07:00 AM
Doc.'s Avatar
Default oxidation??
how do i get rid of clear coat oxidation, whats the best way, can wax help or wet sand???????????????
Old Jun 27, 2004 | 07:59 AM
EvilPinkEye's Avatar
Default Re: oxidation?? (EG6-R)
doesn't wet sand work 1500-2000 grit then a nice wax??
Old Jun 27, 2004 | 08:07 AM
Doc.'s Avatar
Default Re: oxidation?? (EvilPinkEye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPinkEye &raquo;</TD></TR><TR><TD CLASS="quote">doesn't wet sand work 1500-2000 grit then a nice wax??</TD></TR></TABLE>
i dont know, does it??
Old Jun 27, 2004 | 10:22 AM
Doc.'s Avatar
anyone?????
Old Jun 27, 2004 | 11:04 AM
Mr.Fairlady's Avatar
yes,.I found a bit on mine when I buffed a Panel yesterday.
Oxidation is " Dottie type spec's " in the clear.
&lt;---blk car BTW
Old Jun 27, 2004 | 11:36 AM
Doc.'s Avatar
Default Re: oxidation?? (Mr.Fairlady)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Fairlady &raquo;</TD></TR><TR><TD CLASS="quote">yes,.I found a bit on mine when I buffed a Panel yesterday.
&lt;---blk car BTW</TD></TR></TABLE>
so r u tellin me that wetsand and wax is what will take care of it??
Old Jun 27, 2004 | 11:37 AM
kappa's Avatar
i had this problem too. it was attacking pretty much my entire car. the best thing you can do to slow down the process is to maintain a nice coat of wax. the only cure is to havec the whole panel repainted ... that's what i had done and it looks really good now
Old Jun 27, 2004 | 11:50 AM
B_CRUZ!'s Avatar
I just bought a milano red car and the roof was oxidized pretty bad to the point where it was pink. By a clay bar, rubbing compund and a good wax and use it in that order. I saved my car big time. I wish I took before pictures because it made a hell of a difference. So far I only got to do that roof, trunk lid and hood. I still need to do the sides.
Nothing is sexier than touching a car that feels like smooth glass and reflects like a mirror.
thanks to B U N M A N G O's thread up top.
Old Jun 27, 2004 | 12:09 PM
Doc.'s Avatar
Default Re: oxidation?? (B Cruz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B Cruz &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a milano red car and the roof was oxidized pretty bad to the point where it was pink. By a clay bar, rubbing compund and a good wax and use it in that order. I saved my car big time. I wish I took before pictures because it made a hell of a difference. So far I only got to do that roof, trunk lid and hood. I still need to do the sides.
thanks to B U N M A N G O's thread up top. </TD></TR></TABLE>
nice
where did u get the materials from, i know i can get the wax and maybe the rubbin compound from advanced or somethin but the clay i prolly would have hard time findin, unless u know of a place
Old Jun 27, 2004 | 12:53 PM
B_CRUZ!'s Avatar
you can find the clay bar at advance also. should be right next to the rubbing compund and the wax. USe the rubbing compund to get rid of the oxidized layer. The detailing clay bar is just an extra step to remove tree sap and fall out. I was never a detailing buff but after seeing the milano shine, I will invest in a porter cable.
this is what I did.
spray the quick detailing fluid on. use a lot in one area at a time.
rub the clay bar in a left to right motion. make sure it is very well lubricated so the bar won't stick.
wipe off with 100% cotton terry clotch towel.
use the rubbing/polishing compund in small area's at a time. DO NOT DO IT IN A CIRCULAR MOTION. go left to right or up and down. no need to press hard at all.
buff the compund off and wax.
I could have swore my paint was history but I saved it. today was the first day I took it out in the sun and its blingin!
Oh yeah, make sure you do it in the shade and that the cars surface is cold.
-Byron
Old Jun 27, 2004 | 01:01 PM
EkEli's Avatar
rebmem roines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B Cruz &raquo;</TD></TR><TR><TD CLASS="quote">you can find the clay bar at advance also. should be right next to the rubbing compound and the wax. Use the rubbing compound to get rid of the oxidized layer. The detailing clay bar is just an extra step to remove tree sap and fall out. I was never a detailing buff but after seeing the milano shine, I will invest in a porter cable.
this is what I did.
use the rubbing/polishing compound in small area's at a time. DO NOT DO IT IN A CIRCULAR MOTION. go left to right or up and down. no need to press hard at all.
buff the compound off and wax.
-Byron</TD></TR></TABLE>
I did steps similiar to this a couple weeks ago and it seems like the oxidation still comes back quite quickly. Even a week after it seems like it oxidation is coming back and gives me the nerf to want to do it again. I seems to clay bar my car, polish and wax it atleast once a month in order to make it look semi good. I have a friend with the same color car as mine and similiar year and he waxs it like once every 3-4 months and his paint is no wear even comparable. His paint is far superior and I think the only hope is to repaint.
Old Jun 27, 2004 | 01:02 PM
B_CRUZ!'s Avatar
Default Re: oxidation?? (bruce_eli)
is your car always in the sun? and do you use cheap wax/products?
Old Jun 27, 2004 | 01:04 PM
Doc.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B Cruz &raquo;</TD></TR><TR><TD CLASS="quote">is your car always in the sun? and do you use cheap wax/products?</TD></TR></TABLE>
yes it is , i dont wax my car, never have before
Old Jun 27, 2004 | 02:25 PM
Doc.'s Avatar
spray the quick detailing fluid on..
Old Jun 27, 2004 | 02:26 PM
B_CRUZ!'s Avatar
it comes with the clay bar kit.
use this...
then this...
then I used a lot of this...
and not sure if this is bad or not but I also used this...
on top of the NXT.
Old Jun 27, 2004 | 02:28 PM
Doc.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B Cruz &raquo;</TD></TR><TR><TD CLASS="quote">it comes with the clay bar kit.</TD></TR></TABLE>
oh
thanx man u helped alot
Old Jun 27, 2004 | 02:35 PM
B_CRUZ!'s Avatar
bizzump./
pfcle
Honda Civic (2006 - 2015)
May 30, 2007 09:13 PM
LAH
17
Mar 19, 2007 08:25 AM
GURU-DA
Mar 4, 2007 08:43 AM
Skelly
Aug 19, 2005 02:28 AM
mrmonk
Apr 15, 2004 11:08 PM
