oem kit problem
Old Aug 24, 2002 | 05:37 PM
GSblueRacing's Avatar
Default oem kit problem
Does any 1 have the same problem. I installed the OEM 98+ kit into my car and found out that the driver side rear piece didn't line up probably at the corner where it wraps around to the inset of the rear bumper. I thought it was just me but when I met up with another person who also has the kit had the same problem. So I was like is this a defect or something.
Old Aug 24, 2002 | 07:15 PM
B00ST2nR's Avatar
Default Re: oem kit problem (GSblueRacing)
Oh man. You had the SAME exact problem as I did. I fixed it tho. You gotta take it off again and drill a bigger hole. Then it will click on perfectly...
[Modified by Skunk2nR, 8:15 PM 8/24/2002]
Old Aug 24, 2002 | 07:16 PM
akhom's Avatar
yeah same problem.
I just adjust the rear attachment / clip bolt.
Old Aug 24, 2002 | 07:50 PM
neo1z's Avatar
Default Re: oem kit problem (akhom)
same here
Old Aug 26, 2002 | 06:07 AM
BlackAckeR's Avatar
Default Re: oem kit problem (neo1z)
same here
Yeah, what he said....
Old Aug 26, 2002 | 10:04 AM
bullz's Avatar
Default Re: oem kit problem (BlackAckeR)
I found these on the net, maybe they help...
CDN Yellow ITR
May 26, 2006 11:13 AM
RavRSX
15
Nov 26, 2004 09:47 AM
Rtistik.
Jul 2, 2003 05:52 PM
(__________)
Sep 17, 2002 12:44 PM
