Flex Additive
Old Aug 25, 2003 | 10:05 AM
rMak's Avatar
Default Flex Additive
i was wondering if the flex additive was supposed to be added to the primer or the actual paint. not really sure what it is just know that i need it on the lip and sides. thanks
Old Aug 25, 2003 | 08:13 PM
rMak's Avatar
Default Re: Flex Additive (slowEJ8)
bump
Old Aug 25, 2003 | 08:38 PM
KEVlN's Avatar
New User
Not sure about the flex additive, but a guy on HT painted his lip using this bulldog stuff.
Old Aug 25, 2003 | 08:41 PM
GroundZer0 336's Avatar
bump, i need to know too, and if you dont know what it is slowej you put it in the paint so the paint will flex w/out cracking, so if you have a body kit or paint the trim on your car it wont crack if the piece moves.
Old Aug 25, 2003 | 08:47 PM
rMak's Avatar
Default Re: Flex Additive (lowlife4life)
reason im asking is because im trying to get a lip from someone, and he offered to sand it down and primer it. so im wondering if the primer needs flex additive.
Old Aug 25, 2003 | 10:38 PM
JapSpec954's Avatar
where do you get tha flex additive from? any local auto store?
Old Aug 26, 2003 | 12:38 AM
tnbigdawg's Avatar
Default Re: Flex Additive (JapSpec954)
Flex add usually goes into the primers. puting them into the base color can alter the color depending on what type of paint. putting them in the clear can cause dieback(loss of gloss).
Flex add only allows a certain amount of time for your paint to flex. after awhile the flex add evaporates out of the paint.
Old Aug 26, 2003 | 08:12 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
good explaination.....thanks dawg...
Old Aug 26, 2003 | 09:28 AM
rMak's Avatar
Default Re: (dgonzals)
alright, so i should make sure the guy uses flex additive in the primer, and when i go to a shop and have them shoot it, they wouldnt need the flex additive?
Old Aug 26, 2003 | 07:58 PM
rMak's Avatar
Default Re: (slowEJ8)
bizzump?
Old Aug 26, 2003 | 08:27 PM
Crxer's Avatar
i added it to both. add a little more to the front bumper is what i was told. You only need to add a little bit.
Old Aug 26, 2003 | 09:59 PM
ArinX's Avatar
Default Re: Flex Additive (Crxer)
http://www.paintscratch.com
they mix the flex additive in the paint and clear coat if you request it.
Old Aug 26, 2003 | 11:33 PM
tnbigdawg's Avatar
Okay the thing is, if you're getting a bc/cc (Base coat/Clear coat) urethane paintjob, then you don't really have to worry about flex add because urethane is flexible to some extent.
I have added Flex add into a Single Stage paint before without problems, but the color was white for a honda civic. If it were metalic, i wouldnt use it, same with pearls etc...
Old Aug 27, 2003 | 02:08 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (tnbigdawg)
yeah, flex additive is only used for assembly.
Like, if you painted the bumper off the car and were going to throw it around while putting it on the car. Once fully assembled, the additive will evaporate, as stated above.
Test the lip fitment. If it's good, then just paint it. If it's not, then make it fit right, and then paint it.
If you hit something hard enough, it's gonna scratch/chip regardless
Old Aug 27, 2003 | 06:54 AM
2000CX's Avatar
Default Re: Flex Additive (KEVlN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KEVlN &raquo;</TD></TR><TR><TD CLASS="quote">
where can i get custom color cans like this one? i want to paint my side skirts myself...but i can not find oem VSM paint anywhere.
Old Aug 27, 2003 | 09:59 AM
KEVlN's Avatar
New User
Default Re: Flex Additive (2000CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX &raquo;</TD></TR><TR><TD CLASS="quote">
where can i get custom color cans like this one? i want to paint my side skirts myself...but i can not find oem VSM paint anywhere.</TD></TR></TABLE>
Old Aug 27, 2003 | 10:57 AM
dgonzals's Avatar
i forgot all about that link..thanks...i got to choose a new paint job...
Old Aug 27, 2003 | 07:42 PM
rMak's Avatar
thanks guys for the info
19Accord97
Paint and Body
Jul 30, 2010 01:12 PM
oahc
Paint and Body
Apr 28, 2009 06:16 PM
mikeunreal2
26
Jul 19, 2006 09:49 AM
Briman2021
May 4, 2002 04:44 PM
N0E5cape
Apr 8, 2002 09:54 AM
