Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
TSX retrofit in my 2006 Accord, Pics!! Thoughts?
Old 02-25-2007, 05:56 AM
Fuster_Cluck's Avatar
Default TSX retrofit in my 2006 Accord, Pics!! Thoughts?
NEW PICS FURTHER DOWN THIS PAGE
Something is definitely not right after viewing a couple other TSX retrofitted threads on HIDplanet (HDP). I've posted the pictures on HDP asking for help. I'll go ahead and post them here too.
--2006 Honda Accord LX sedan
--Hella GEN 3 ballast and bulbs (purchased from HDP)
--TSX retrofit in OEM housings
Here are some pics from last night:
1. Up against a wall from 25 feet:
2. Dark road:
3. View from further back:
4. View from directly in front of the headlights / center of bumper:
5. View of the housing:
It seems like the cutoff on the ground (guess that is what it's called) is not out far enough. I measured the ground cutoff when I got home. The passenger side was about at 50 feet and the drivers was about 35 feet. The uneven ledge from each light doesn't feel right. Also, in pic #4 you can see a duplicate cutoff just not as bright that is just past where the asphalt ends. It's an exact replica of the bright cutoff just not nearly as bright and really about worthless. The only real light I am getting seems to be just in front of the car
Thanks for any input
Modified by Hybrid93Hatch at 12:44 AM 3/9/2007
Old 02-25-2007, 06:14 AM
hadehatch's Avatar
Default Re: TSX retrofit in my 2006 Accord, Pics!! Thoughts? (Hybrid93Hatch)
looks like the projector is pointing downwards too much.. adjust the headlights
Old 02-25-2007, 07:47 AM
TurbothisLS's Avatar
Default Re: TSX retrofit in my 2006 Accord, Pics!! Thoughts? (hadehatch)
yea, your cutoff is supposed to be straight ahead, not on the ground
Old 02-25-2007, 09:39 AM
SneezinCD5's Avatar
Hope you get them looking right. I know you waited like 8 months for the guy to send you all your **** to you.
Old 02-25-2007, 09:48 AM
I read the cutoff is supposed to be 2.1-2.5" lower than the stock headlamp. I adjusted the drivers side to that from 25 feet. I need to figure out how to properly aim these. Anyone have any ideas? Thanks!!
Old 02-25-2007, 10:02 AM
Type X's Avatar
Default Re: (Hybrid93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I read the cutoff is supposed to be 2.1-2.5" lower than the stock headlamp. I adjusted the drivers side to that from 25 feet. I need to figure out how to properly aim these. Anyone have any ideas? Thanks!!</TD></TR></TABLE>
you aim them just like oem equipment
put the phillips in the headlight and turn
its in your manual
my retrofit is built to the reflector so you can still aim up and down
Old 02-25-2007, 10:13 AM
6SPD_EK's Avatar
Default Re: (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">
its in your manual
my retrofit is built to the reflector so you can still aim up and down </TD></TR></TABLE>
what he said ^
look at cutoff I marked in red
you need to adj one light upward
& maybe adjust them left to right... as the 2 steps (from internal shield should be 3-4 ft apart
Old 02-25-2007, 11:52 AM
Default Re: (6SPD_EK)
Thanks guys for the input. I was measuring from the other cutoff that is about 20-22" up the wall in the pic
Back at it again tonight
Old 02-25-2007, 01:38 PM
nautica_t's Avatar
did you do a color mod?
Old 02-25-2007, 02:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nautica_t &raquo;</TD></TR><TR><TD CLASS="quote">did you do a color mod?</TD></TR></TABLE>
No color mod. Just wanted OEM HIDS w/o spending 30k on a car
6SPD_EK - Is my drivers side cutoff just as low. It looks like it may be even with the bottom of the glass on the door when looking just right of the door.
Thanks for the input!!
Old 02-25-2007, 02:31 PM
fliplyricist1's Avatar
first and foremost, you need to find a perfectly level or close to level place to aim
try someplace like a parking garage after-hours
and yeah, it appears your passenger side beam is wayyy too low
the top 'steps' of both your cutoffs should 2 inches below the measured distance 'from the ground to the center of your headlights' from 25 feet, and the horizontal placement of the beginning of the 'steps' should not waver at all from 25 feet (should remain the same distance appart as the projectors on your headlights)
Old 02-26-2007, 04:49 AM
nautica_t's Avatar
your on HDP and didn't get what i mean. i thought you did the color mod on the tsx projo's because there is more blue rather than a sharper cut off.
Old 02-26-2007, 05:58 AM
your on HDP and didn't get what i mean. i thought you did the color mod on the tsx projo's because there is more blue rather than a sharper cut off.</TD></TR></TABLE>
I know about using the washers to change the color. I also know the cutoff can be distorted with this mod. I just wanted OEM HIDS (nothing more, nothing less).
I raised the passenger light up and also the drivers a little. I did this close to home and on the way back 1 of the 2 cars flashed me at a close distance. So, I went out in the garage a couple minutes ago and lowered the driver light. I'll take the scredriver with me today just in case I get the same thing on the way home tonight
Old 02-26-2007, 07:09 AM
Mr. Vapor's Avatar
did you do the retro yourself or no?
i have an '03 Accord id like to retro but havnt found a substantial DIY yet...
Old 02-27-2007, 08:00 PM
994TurboCoupe's Avatar
so who did your lights?
Old 02-27-2007, 08:12 PM
waddy41's Avatar
Old 02-27-2007, 08:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Vapor &raquo;</TD></TR><TR><TD CLASS="quote">did you do the retro yourself or no?
i have an '03 Accord id like to retro but havnt found a substantial DIY yet... </TD></TR></TABLE>
jwhite on HID planet did the retrofit.
The lights are just about perfect. I will post pics most likely tomorrow night
Old 02-27-2007, 08:35 PM
Imperious: Mod of Valor
JDM-EJ1's Avatar
Default Re: TSX retrofit in my 2006 Accord, Pics!! Thoughts? (TurbothisLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbothisLS &raquo;</TD></TR><TR><TD CLASS="quote">yea, your cutoff is supposed to be straight ahead, not on the ground</TD></TR></TABLE>
Old 02-28-2007, 02:40 AM
6SPD_EK's Avatar
yeah looks like its aimed low - right at the same height of bottom of the glass.
Old 02-28-2007, 03:32 AM
redEH2's Avatar
i had the same problem on my civic
Old 02-28-2007, 03:38 AM
KYLE.'s Avatar
yeah you can really tell the difference in that i read something the other day about tsx lighting ill see if i can find it again
Old 02-28-2007, 06:22 AM
Default Re: TSX retrofit in my 2006 Accord, Pics!! Thoughts? (JDM-EJ1)
i think he has his own web site now.. jwhiteslights.com
Old 03-08-2007, 08:43 PM
I think my drivers side is a slight bit lower than the passenger light. Thanks for any input.
Some pics I just snapped:
1:
2:
3:
4:
5:
6:
7:
Digital camera vid so not the best quality:
HID vid 1
HID vid 2
Old 03-08-2007, 10:54 PM
Doctor X's Avatar
Old 04-16-2011, 11:54 PM
edwinbaby's Avatar
Do you know of any DIY post on how to retrofit the 7Gen headlights? (I'm trying to do mine).
Quick Reply: TSX retrofit in my 2006 Accord, Pics!! Thoughts?
