Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
DIY: Crosstour license plate light bulb replacement
Old 01-11-2014, 01:22 PM
tlarimer's Avatar
Default DIY: Crosstour license plate light bulb replacement
After doing a search and only coming up with threads stating you need to remove the interior trim panels to replace the rear license plate bulbs, I decided to to make this quick DIY showing how to replace them from the outside in 5 minutes.
First, use your finger or a screwdriver to gently pry the right side(drivers) towards the left side(passengers) and pull back, this will release the right side.
Gently pull the housing towards the back of the vehicle:
Rotate the housing until it pops free of the tailgate assembly:
Push the gray release tabs on the back of light socket to remove the outer lense, giving you access to the bulb:
Replace bulb and reverse directions.
Hopefully this helps somebody out.
Tim
OLi82
01-20-2018 06:00 PM
Mfoehrkolb
09-09-2013 10:38 PM
fergs96integra
06-05-2013 03:32 AM
SUPABLUEV6
12-31-2008 02:33 PM
Mr.Speed
05-01-2005 12:19 PM
Quick Reply: DIY: Crosstour license plate light bulb replacement
