Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
HELP! ATF leak from cooler line at bottom side of radiator!
Old 06-24-2019, 11:04 AM
Chris_WRB's Avatar
Default HELP! ATF leak from cooler line at bottom side of radiator!
Okay hear me out. I've looked all over including other forums and I cant quite seem to find the right answer here. No I've noticed I have an ATF leak from the cooler line fitting (or seal?) At the bottom passenger side of the radiator(supply side?) Anyways, I'm trying to figure out whether or not that fitting is removable and replaceable. I've called a few dealerships and they said a whole new radiator is the only oem option, thet don't sell the fitting separately.
Has anyone fixed this issue before? Any direct replacements you know of? It's not dumping fluid but I'm going to flush the entire system and there's no point in doing so when it leaks so I'm trying to fix this first. Any help appreciated!
EDIT: I have a 2007 Accord LX Sedan 2.4l ‐ Automatic
