Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 Accord ac clutch wont engage.
Old 05-18-2017, 08:30 AM
justin.d.keller's Avatar
Post 04 Accord ac clutch wont engage.
04 Accord AC clutch wont engage. Need help troubleshooting the electrical controls. I have swapped relays and still don't work.
Old 05-19-2017, 08:42 AM
DCFIVER's Avatar
Default Re: 04 Accord ac clutch wont engage.
Connect a scan tool and look for the AC request PID. That will start you in the right direction.
Old 05-19-2017, 08:52 AM
I don't have a scan tool. Is that a must? If so what's a decent one to buy that won't break the bank as I try and do all my automotive work
Old 05-19-2017, 10:58 AM
DCFIVER's Avatar
On a modern vehicle, Id say so. It would certainly shorten your diagnostic time.
For a DIYer its hard to say. Would you even understand the data you were looking at? Not likely,in which case any scanner is probably a waste of money. But for what its worth the Autel DS 708 will give you the best bang for your buck. There are newer versions of Autel available,but IMO the 708 will suit a DIYer just fine.
If a scanner is not an option,you still need the right equipment to help you out. DVOM, wiring diagram, AC manifold gauge set, for starters.
Old 05-19-2017, 12:30 PM
I have a meter I have the AC manifold gauges I'm having a time trying to find a wiring diagram for the air conditioner. I've looked on the internet and cannot find anything
Old 05-19-2017, 12:47 PM
DCFIVER's Avatar
http://www.alldatadiy.com/index.html
Factory diagrams,for a fee of course.
Old 05-30-2017, 09:56 PM
SuperFast3000GT's Avatar
I assume you've checked the other obvious things like the pressure switch? Freon level? Try jumping the pressure switch harness and that will rule out if it's bad or if you are low.
Old 06-05-2017, 02:05 PM
mrau92me's Avatar
My mom-in-law's '03 Accord LX with 114k miles is having similar issue. Another way to send power to the clutch coil to see if it clicks is to pull the relay (the one indicated by the lone snowflake on the fuse box lid diagram). Use a coated wire to jumper connect the female sockets where the relay's #1 & #2 connectors plug into. Those #1 & #2 sockets are the ones that are toward the back of the car. If the clutch doesn't click and you know there's continuity from the #2 socket to the clutch coil, then IMO, the clutch coil is toast (like my mom-in-law's car's is). In my case, for further confirmation, after testing the '03 I even performed the jumper test on my wife's '07 Accord EX (same engine). It clicks loudly, whereas the '03's didn't even come close to clicking.
Robert04accord
05-29-2014 04:39 PM
jhuck
04-27-2013 11:14 PM
CG01
Engine Management and Tuning
10-01-2012 03:00 AM
dstatechamps
07-26-2011 04:21 AM
Quick Reply: 04 Accord ac clutch wont engage.
