Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
06 accord 4cyl turbo
Old 02-05-2011, 11:11 PM
xtant56's Avatar
Default 06 accord 4cyl turbo
i got a turbo kit installed on my 06 accord 4cyl and the maf light keeps coming on...code p0103...how can i fix this problem?
Old 02-06-2011, 05:45 AM
LPED's Avatar
Default Re: 06 accord 4cyl turbo
Sounds like you are maxing out MAF sensor .
Do you have some kind of fuel management ?
Not sure whats compatible for Honda but you probably need either a way to clamp the MAF sensor (so not max it), this can be one with a interceptor/piggyback type unit or completely remove MAF unit signal with speed density type converter (like HKS VPC but it is no longer made).
If your sucking through MAF you could also try blowing through it to see if better results , sorry don't have first hand experience on Honda turbo installs, not to many are done .
davescott
Honda CR-V & Element
08-25-2017 04:44 AM
xr4ti
07-30-2001 02:48 PM
Quick Reply: 06 accord 4cyl turbo
