Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Cutting down Coil Springs
Old Mar 6, 2026 | 02:35 PM
slantnoseC10's Avatar
5 Year Member
Default Cutting down Coil Springs
On our 03 Accord I4 cyl in the past I changed all four strut assembly complete (aftermarket parts) and the fronts are now Stiffer then before. Can the frt coil springs be cut down 1 coil too make it ride a little softer or is this a bad idea?
thanks ahead of time on any help
Old Mar 6, 2026 | 06:18 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: Cutting down Coil Springs
That’s the opposite of how a spring works, it would become stiffer if you cut it.
It’s generally a terrible idea to cut springs, for a multitude of reasons. Are you sure it’s not just feeling stiffer because you replaced your old worn out junk with fresh parts?
Old Mar 7, 2026 | 07:19 PM
5 Year Member
We are the only owners so we know this car very well, both of us have the same thoughts with it being bumpier or bouncer then before the change over. It was a much much softer ride from 7 miles from new to just over 300K when struts were all changed out.
Old Mar 8, 2026 | 07:16 AM
spAdam's Avatar
Loved
Community Favorite
If you replaced with aftermarket parts it's certainly possible. They may use the same spring rate for I4 and V6 configs and the valving is likely different than the oe dampers. f you replaced with oe parts and they are the correct ones for the car, it's more likely that you're noticing just how worn out your old stuff was. At 300k, your old springs were certainly softer than they were when new.
Is the car higher than original (or before replacing parts)?
Old Mar 8, 2026 | 02:39 PM
5 Year Member
Seams like the front is pretty much the same height off the gound like always but the rear seams taller off the ground maybe one or so inches from top tire to top of arch in wheel well.
s2kwildride
Honda S2000
Feb 23, 2007 06:34 PM
oilguzzler
Oct 13, 2006 03:36 PM
akaplan12
Sep 16, 2006 01:03 PM
kent
Jan 6, 2003 10:24 AM
TruckinCowboy
Mar 25, 2002 08:50 PM
