Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Can you turn off seatbelt chime?
Old 07-08-2009, 11:23 AM
  #51
New User
ballerstatus99's Avatar
Default Re: Can you turn off seatbelt chime? (bic032)
Originally Posted by ch0baca
i drove one time without the seat belt on for about 5-10 mins, and it just stops beeping after that time, weird
That must have been a pretty annoying 5-10 minutes.
ballerstatus99 is offline
Old 07-08-2009, 11:32 AM
  #52
hieuamn's Avatar
my ex drove an accord, and i agree that beeping is very annoying. but if i was driving all i did was just sit on the seatbelt. I'm very stubborn
hieuamn is offline
Old 07-09-2009, 06:50 AM
  #53
New User
shockwave28's Avatar
Has anyone actually contacted Honda to see if there is a way to turn it off using HIM ???
I know with allmost all nissan cars, any chime/ safety feature can be tured off. Its not something most dealers will do, for liability reasons.
shockwave28 is offline
Old 07-11-2009, 10:10 PM
  #54
New User
Fendercover's Avatar
On my SI I ended up taking out the cluster and removing the chime on the board, with a steady hand it's quite easy to do. Just take your time and only touch the terminals on the chime itself. Or you should be able to gently rock the chime back and forth as it has a tad bit of play and it will break the wires that are soldered onto the board. I unsoldered my as if I sell it I'll be able to put it back.
Fendercover is offline
Old 07-12-2009, 11:36 AM
  #55
DEEABLO's Avatar
buckle up the seatbelts when you're not in the mood to buckle up, and sit on the seatbelt.
DEEABLO is offline
Old 07-12-2009, 12:22 PM
  #56
Function>Fashion
Harlowe's Avatar
If you have a small allen wrench you can "buckle" the belt. Just push down the metal bar inside of the buckle from the top. Works on Civics anyway.
Then when you want to put the belt on just push the red button, and it will release.
Harlowe is offline
Old 07-12-2009, 03:07 PM
  #57
KWayRacing's Avatar
Originally Posted by acura_el2000
WOW the amount of **** smoking ********* preaching safety in this thread is astounding! Go do some community service or something if your that concerned with the well being of others.
Also READ, the OP wants to drive on his DRIVEWAY without a seatbelt..some people actually have long driveways.
-OP I know that in my fathers Corolla there was a trick to disable it... you had to turn the keys to accessory (II) and clip the belt in and out about 7 or 8 times, the chime would sound off twice to let you know it was disabled. Try this method out on your accord it could work.
oh and just for the ********, the reason I disabled it was because on Thanksgiving I had gotten a bunch of groceries and a turkey and set them on the passenger seat.. The car thought it was an unbuckled passenger and beeped for nearly my whole trip home.
stupid electronic nannies like these are ridiculous and should never be considered safety measures, because if you are too stupid to buckle your seatbelt without an annoying chime then you are the lowest denominator, as in DUMB AS ROCKS. Whats next? A chime to let you know that you are driving with only one hand? or a chime to let you know that you haven't looked into your rear view mirror in the last 2 mins?
Wow you rode with a loose frozen turkey inside your car and you call someone else stupid. Loose frozen turkey + car crash= Turkey Missle.
KWayRacing is offline
Old 07-12-2009, 06:02 PM
  #58
PyroProblem's Avatar
Well since were onthe topic of disabling safety features on our cars, does anyone wanna know how to blow up a car with an 02 sensor?
Or maybe jump the airbags to the horn or starter relay? Thats a good one! LOL
PyroProblem is offline
Old 07-16-2009, 11:25 AM
  #59
Mr.Insurance's Avatar
Yes, the seat belt chimes are so annoying.
Mr.Insurance is offline
Old 07-17-2009, 08:37 AM
  #60
aCCordcHIka06's Avatar
Or is there a way to make it not go off AS much as it does? I have this problem only on the passenger side. Because it is registering weight in the passenger side I know if my fiance doesn't put his seatbelt on right away it goes off. And it is annoying and I always bug him to do it quickly cuz it irritates the shizzy out of me. But maybe check with the Honda dealer they probably know? Nothing in the manual I take it?
aCCordcHIka06 is offline
Old 07-28-2009, 04:27 PM
  #61
New User
delcov's Avatar
I have a 2005 Honda CR-V. The seatbelt indicator does not go off when I plug in the seatbelt. And so now I get that annoying beep every minute or so. I always wear my seatbelt, and I don't want to get ripped off at a Honda dealership. Is there any way to disable the alarm (similar to disabling the BeltMinder feature in a Ford)? I've looked at the wiring schematics and don't see a fuse for this feature. Any help would be appreciated. I'm at my wit's end, short of taking it to a dealership and paying whatever ungodly amount they want to fix this feature.
delcov is offline
Old 07-31-2009, 06:17 PM
  #62
nastycobra's Avatar
Originally Posted by hometheaterman
On my 06 Accord V6 6speed it beeps if you don't put your seatbelt on it and every few seconds keeps doing it until you finally put it on. It also does this for the passenger. This is very very very annoying. Is there a way to disconnect this or turn it off? I don't often not wear my seatbelt but if I just ride up the driveway or something I don't want this thing beeping the whole way.
the honda dealer can do it if u know somone in there they plug it up the computer and they can change that i think i know thats how i did on my mustang
nastycobra is offline
Old 07-31-2009, 09:04 PM
  #63
BLKFLSH's Avatar
When you die sitting on the seat belt, will it be worth it? It will be too late to change your stupid ways then.
BLKFLSH is offline
Old 02-10-2010, 12:33 PM
  #64
New User
voltageROCK's Avatar
The only thing I can think of is to find the speaker that beeps, disconnect one of the wires and run it to a switch that you can turn on and off. There is a spot on my '06 Civic to the left of the steering wheel that you can put a switch in (I believe it's where the fog light switch goes if you have that feature on your Civic). You can either get the OEM switch from Honda or do a search for OEM Honda parts and most likely get it much cheaper online, or just buy a toggle switch from Radio Shack, and mount the switch in the spare plate. This way, you have control of the speaker being on or off
I would not suggest doing any other modifications to your Civic (using paper clips or cutting wires for example!!) as you can disable your driver or passenger airbags among other things that you do not know of. The 06' Civic also has a sensor in the passenger seat that detects a certain weight. I believe 20 pounds and under disables the airbag, as a baby seat can be in the front and the last thing you want is the airbag deploying. Messing with any of the wires under your seat can truly screw up your car, especially if you cut some. You would be really screwed when you want to sell the car too!
The safest way is to find the speaker, and hook it up to a switch like described above. That way, you can always take out the switch and hook the speaker back up if you sell your car.
Personally, I think that seat belt reminder, as annoying as it can be for passengers who don't like putting on their seat belts, is a great feature. No matter how good of a driver you are, that means nothing if some idiot or drunk driver swerves into your lane head on! I think I would be really happy my seat belt was on in that instance!
voltageROCK is offline
Old 02-10-2010, 01:51 PM
  #65
93LsVx's Avatar
instead of this, just find the speaker, and give it a good smash, like with a hammer.. or a good pinch.. with some pliers
93LsVx is offline
Old 04-19-2010, 03:17 PM
  #66
chrislanglois's Avatar
hello all. i want to know the same thing. can you turn it off. and dont give me that buckle up crap ive got harnesses so i do just not with the factory belts. and for the record the airbag system is all on its own. i am a body man. and mainly work on the air bag system. the air bag system has nothing to do with the seat belt on the driver side or the passinger side. the only time the airbags and seatbelts are together is when the car says that there is something in the seat or not. if there is noone in the seat the pass bag wont go off and if there is it will. the only thing that makes the airbags not go off is the car. it is smart. like if you get hit in the rear wether you have your seat belt on or not it shouldnt deploy. because if it does it will hit you when youy are going forward and smash you back and cause wiplash and may break your neck. head on it will because of where the force is it then acts as a cushion. so... yeah...
chrislanglois is offline
Old 04-28-2010, 08:59 AM
  #67
accht's Avatar
This is actually a valid question. Subarus do the same thing, but you can disable the constant reminder beeps by following a certain procedure, which involves buckling and unbuckling the seatbelt 15 times in 15 seconds. Yes, you feel like a madman during the procedure, but it solves the problem. Afterwards, it will beep for one series (about 5 seconds) if you don't buckle up, but won't keep bugging you as you drive after that. Nothing else (SRS etc) is affected. Honda probably has a hidden way to do this as well, and hopefully someday we'll hear about it.
accht is offline
Old 05-14-2010, 06:18 PM
  #68
cmcfaul's Avatar
This board is USELESS. A dozen people asked the same questions and all you get are a bunch of old ladys telling me I have to wear my seat belt. The question asked repeadly was how to turn off the buzzer. No one asked for any other response other then the technical know how of how to disable the buzzer. All you safety fanatics should wear a full body suit every time you walk down the street or sleep in your bed for fear a car might get you. Safety first!
I NEVER wear my seat belt. My desision, none of your bisiness. The buzzer bothers me. I would like to know how to disable it without affecting air bag deployment etc. got a problem with my decision....bite me.
So unless someone can tell me how to turn the buzzer off please save the safety lectures for someone who cares (no one on this board) and keep your oponions to your self. This board is supposed to be usefull and the idiots who posted everything but the answer to question should go away.
So, anyone have the answer? Probably not
cmcfaul is offline
Old 08-04-2010, 10:36 AM
  #69
SeatBeltWearer's Avatar
Icon3 Re: Can you turn off seatbelt chime?
Here here.
You people should keep your mouths shut if you don't have an answer to this question.
I always wear my seatbelt.
This morning, my car stopped recognizing the seatbelt; and now the car beeps to remind me every 20 seconds.
So stop telling us how important it is to wear a seatbelt and tell me how to turn this noise off. It is maddening.
- Ben
SeatBeltWearer is offline
Old 08-06-2010, 05:14 AM
  #70
johnnykash's Avatar
click it or ticket brahhhh
johnnykash is offline
Old 08-06-2010, 08:34 AM
  #71
He knows where you live!
TheMuffinMan's Avatar
Does anyone else find it hilarious the number of brand new, 1 post members on the board? Who joined JUST for this thread?
Here's the top tip, go to the junkyard or eBay, buy a seatbelt clip for your car and clip it in. Chime disabled.
Some people are just retarded, why would you want to disable a switch, remove a speaker, etc? All the car wants is something plugged in. So plug something in.
TheMuffinMan is offline
Old 08-06-2010, 08:36 AM
  #72
Originally Posted by SeatBeltWearer
Here here.
- Ben
Spray electrical contact cleaner down the seatbelt slot (test for discoloration first on plastic in small area) My guess is you have spilled soda, or a skittle or something and gummed up the contact in there.
You also do not mention your year/make/model at all so I have no idea if you're referring to your 92 Ford Mustang LX or if you're referencing a 2011 Accord EX-V6.
Old 08-21-2010, 06:41 AM
  #73
randerton's Avatar
I have been following this topic every since we purchased our 2008 Odyssey. I am in the camp of wanting to use my own brain w/regard to safety versus Honda imposing that decision upon me with a very annoying sound. I found a very simple solution that only costs $20 and it works great. Check out this seat belt extended from a company that is using eBay as their storefront:
http://cgi.ebay.com/ebaymotors/SEAT-...Q5fAccessories
This extender clip pops right in the normal seat below buckle and effectively disables the extremely annoying chime while still maintaining the airbag/etc. This way you can actually use your judgment as to when you wear your seatbelt versus a Honda lawyer or engineer imposing their judgment upon you.
randerton is offline
Old 08-21-2010, 09:21 AM
  #74
lazlong's Avatar
It's idiots like you guys is why it's mandatory to wear belts in ALL seats in my state. If they don't want to wear a belt let 'em. It's their own form of population control.
lazlong is offline
Old 08-21-2010, 01:53 PM
  #75
chusoblu's Avatar
Usually I would say go ahead and do what you want and not wear the seat belts. However, I think it is irresponsible to say because of an annoying beep that you can justify disabling the reminder. If you don't feel like a reminder is necessary for you, OK, but don't decide for others who may drive your car or ride in it. Some people DO need reminders.
chusoblu is offline
Quick Reply: Can you turn off seatbelt chime?
