Recall(Is This Valid)
2005 HONDA ACCORD EX L4 2.4 Liter FI
Mfr. Involved HONDA (AMERICAN HONDA MOTOR CO
NHTSA Campaign # 07V001000
Mfr. Campaign # Q31
Component Affected AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE
# Vehicles Affected 81000
Defect ON CERTAIN VEHICLES, THE SEAT POSITION SENSOR (SPS) DETECTS THE DRIVER'S SEATING POSITION AND ADJUSTS THE AIR BAG INFLATION PRESSURE ACCORDINGLY. THE WIRING HARNESS FOR THE SPS WAS ATTACHED TO THE SEAT FRAME IN THE WRONG LOCATION AND MAY HAVE BEEN OVER TIGHTENED. THE SENSOR WIRE MAY BREAK AND CAUSE THE AIR BAG WARNING LIGHT TO BE ILLUMINATED, AND THE SPS TO FAIL.
Consequence A FAILURE OF THE SPS CAUSES THE AIR BAG SYSTEM TO DEFAULT TO FULL INFLATION PRESSURE, REGARDLESS OF THE SEAT POSITION. FULL DEPLOYMENT OF THE DRIVER'S AIR BAG CAN INCREASE THE RISK OF INJURY FOR SMALLER DRIVERS IN A FRONTAL CRASH.
Corrective Action DEALERS WILL REPLACE THE SEAT POSITION SENSOR WIRING SUBHARNESS. THE RECALL WILL BEGIN ON OR ABOUT FEBRUARY 8, 2007. OWNERS MAY CONTACT HONDA AT 1-800-999-1009.
__________________________________________________ ________________
NHTSA Campaign # 07V097000
Mfr. Campaign # Q37 Q38
Component Affected FUEL SYSTEM, GASOLINE:DELIVERY:FUEL PUMP
# Vehicles Affected 166561
Defect ON CERTAIN VEHICLES, A COIL WIRE INSIDE THE FUEL PUMP RELAY MAY BREAK, CAUSING THE FUEL PUMP TO LOSE POWER. IF THE FUEL PUMP BECOMES INOPERATIVE, THE ENGINE MAY NOT START.
Consequence IF THE FUEL PUMP LOSES POWER WHILE DRIVING, THE ENGINE COULD STALL WITHOUT WARNING, AND A CRASH COULD OCCUR.
Corrective Action DEALERS WILL INSPECT AND REPLACE THE FUEL PUMP RELAY FREE OF CHARGE. THE RECALL BEGAN ON APRIL 2, 2007. OWNERS MAY CONTACT HONDA AT 1-800-999-1009.
I found both of these online and was wondering if its a vaild recall. Thanks
Mfr. Campaign # Q31
It Wasn't Me!
1 Post
Re: Recall(Is This Valid) (Accord1234)
Call or stop by you nearest dealer's service department with your VIN in hand. They will run it and see if there are any open recalls on your car. Don't bother mentioning what you found online just ask about open recalls. Honda's recalls tend to be pretty VIN specific.
McCoy
11-02-2014 03:05 AM
accordselux
11-27-2007 05:34 PM
