Honda Accord 2016- 2017 This is the place to discuss all things Honda Accord related for the 2016 -2017
Front left brake squeal?
Old Jun 6, 2025 | 09:28 AM
GrapeLegs's Avatar
Default Front left brake squeal?
Hello friends I've got a 2016 Honda Accord 2.4 L
A few months ago I started experiencing some squealing sounds from the front driver wheel. I assumed it was time to swap the brakes out, It had been a while since I've done it. I got a new four-wheel set of Bendix Priority One pads and the Bosch Quiet Cast rotors. This is not the first time I've changed brakes, everything was fine, got it all put together and the squeal was gone. However after about two weeks of driving, suddenly the same wheel started squealing again. I ignored it for maybe a week figuring there was just, you know, dust build up or something on it and we'd had a lot of rain so maybe just surface corrosion. Eventually I got to the point where It was annoying me so I took the wheel off, cleaned the caliper off again, dusted off the brake pads, and applied new grease but that didn't do anything anything and it continued to squeal So far I've replaced the brake hardware again, slapped more grease on it, went ahead and swapped out the pads and the rotors again on both front wheels, changed the brake lines, changed the calipers, made sure everything was clean and whatever else but it just always comes back and I'm not really sure what else I should be looking for? Maybe like a wheel bearing that's going bad and the extra load from breaking is making it squeak? At this point I'm completely lost what to do. I cannot get this front wheel to stop squealing for more than two weeks or so. It starts squealing at about I don't know 30% breaking force, regardless of what speed I'm going, and stops squealing if I apply more than that. Any thoughts or suggestions would be greatly appreciated
themachinist
Honda Civic (2001 - 2005)
13
Jul 21, 2008 08:58 AM
EH3Civic
15
Nov 12, 2007 11:02 PM
93SiPrelude
Feb 4, 2007 04:34 PM
gooberwolf
Jul 7, 2003 11:21 AM
02WRX
Mar 19, 2002 07:40 PM
