Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Vsa code help
Old 12-30-2018, 04:01 PM
HoldThat's Avatar
Default Vsa code help
If any one can help it will be greatly appreciated . I am useing the bluedrive scanner tool . My car is a 2014 Honda accord hybrid I got 2 code Electronic power steering code (35-06 reserved) and (133-0 vsa signal failure).my car was hit on the right side wheel I hade to replace the wheel bearing and I change the abs sensor to see if the code go away. I try clearing the code but it does not go away There is no light on the dash.
Old 01-01-2019, 04:35 AM
HoldThat's Avatar
Default Re: Vsa code help
Bump
Old 07-01-2021, 06:26 AM
hhhhhhhjjj's Avatar
I had the same problem on my 2015 Honda accord hybrid I took it to the dealership and they told me it was a failed VSA module and it would be $4000 to replace I took it home located it unplugged it waited 10 seconds and plugged it back in and everything is fixed this is why I don’t trust dealerships
mas21958
Honda CR-V & Element
06-13-2019 07:41 AM
HoldThat
12-30-2018 11:27 AM
lvbatb
07-07-2017 11:40 AM
Quick Reply: Vsa code help
