Obd2 Code help
Obd2 Code help
If any one can help it will be greatly appreciated. I am useing the bluedrive scanner I get these 2 code that come up as Electronic power steering code (35-06 reserved) and (133-0 VSA single failure) . The car is a 2014 honda accord hybrid that was hit on the right side wheel. I had to replace the wheel bearing and I replace abs sensor to see if the code will go away but it did not. I did clear all code but it still come back
