Clutch Clicking Noise
Im having this issue where a clicking noise is heard when a clutch is pressed and also when released. There hasn't been any problems in functionality of the clutch. Everything is working fine besides the clicking noise which is driving me crazy. I am attaching the videos for reference. Any input would be appreciated. Thanks
Video 1
Video 2
Video 1
Video 2
I noticed in your video that the click seems to be coming directly from the pedal assembly area rather than the transmission itself, especially since you mentioned the clutch functionality is still perfect. That is a good sign that your actual clutch plate and throw-out bearing are likely fine, and this is just an annoyance inside the cabin.
I would crawl under the dash and press the pedal with your hand to pinpoint the sound then spray some white lithium grease on the pivot points and the clevis pin first this should fix the issue.
kte324
Transmission & Drivetrain
15
Feb 16, 2010 09:40 PM
