Burns oil
no way, that’s way too much oil consumption for a Honda with only 85k miles, don't let anyone tell you that’s normal. It’s a known issue with these engines where the piston rings get gunked up, but you should definitely try swapping out the PCV Valve first. they are really cheap and can have a major impact to your problem it only takes minutes to change. best of luck. cheers
