Wheel Offset Question
Old Jul 24, 2002 | 10:01 AM
greensleeper's Avatar
Default Wheel Offset Question
I order 17" Mille Miglia Carbon Grey HT3's with 205/40 series Yokohama Parada Spec 2's today.
I had a choice between 37 and 45 offset. I took the 37 offset because that is the wider (wheels stick out more) of the two thinking that it would be less likely to rub on the inner fender.
What do you guys think? Obviously either would have worked. But I just wanted to double check. The offset is measured in millimeters so with the 37's the wheels will stick out approxiamately a quarter inch farther than the 45's.
[Modified by greensleeper, 2:02 PM 7/24/2002]
Old Jul 24, 2002 | 10:20 AM
Ludehrt's Avatar
Default Re: Wheel Offset Question (greensleeper)
I have some 40mm offset 17x7.5 Se37s. They fit fine. With yout 37mm wheels, You might have some slight ruubbing (outer fender) problems if you slam your ride too much
[Modified by Ludehrt, 7:22 PM 7/24/2002]
matt94z
Aug 7, 2008 05:03 PM
HS2G
Jun 16, 2007 11:50 PM
portaman03
Honda Civic (2001 - 2005)
Apr 11, 2007 09:31 PM
L4NDO
Mar 30, 2003 03:04 PM
Ohlias
Sep 26, 2002 05:26 PM
