What in the hell...
Old Aug 31, 2001 | 07:06 PM
ArchAngel Sabastian's Avatar
New User
Default What in the hell...
Ok get this i dont understand but maybe its something im overlooking.
I have installed on my car at this moment
CAI
Acell ThunderSport 300Plus Plug Wires
Bosch +4 SparkPlugs.
Ok now when i just got the car and ran it with everything factory i ran it in every gear right to red to "test"
anyhow today on the highway while doing the same thing it cut me off in third gear at about.. 5500 rpm
and after that it wouldnt let floor it in 5th and get past say 4000 rpm. i thought maybe something had got sucked up into the filter but i stoped and all the lines and everything was ok. Now i havent reset the ECU after the CAI and maybe thats it or i didnt think so but do kords have a govenor chip? or rev limiters? thnx for input.
to be specific when i say cut off i dont mean the car shut off i mean it like cut the gas or something as steping on the pedal did nothing untill you let of for about 5 sec's and then you could go again.
[Modified by Sabastian, 8:08 PM 8/31/2001]
[Modified by Sabastian, 8:10 PM 8/31/2001]
Old Aug 31, 2001 | 07:54 PM
Conechaser's Avatar
Default Re: What in the hell... (Sabastian)
It is speedlimited to 118mph or so. But i have redlined 4th gear in my car before, im not sure how fast that is though.
Old Aug 31, 2001 | 07:55 PM
New User
Default Re: What in the hell... (94Accord)
i wasnt even near 118 when it first cut out. i was in third
Old Aug 31, 2001 | 08:18 PM
Conechaser's Avatar
something in your ignition maybe going out then, im not sure. probably something electrical though.
Old Aug 31, 2001 | 08:37 PM
New User
crap....
Old Aug 31, 2001 | 09:02 PM
New User
I re-checked all my lines and my ignition and im reseting the ecu now ill take her out for a run in the moring and let you all know what happens.. hopefully i can say i hit 118 lol
[Modified by Sabastian, 8:08 AM 9/1/2001]
Old Sep 1, 2001 | 02:29 PM
SOHCArchangel's Avatar
well the spark cut stock is close to 6k ,a nd the fuel cut is 6500, i have a 7k rpm pill in my msd, i have no problem going over 118, 132 is when the stock ecu cut my fun off, check your distruibutor and rotor
Old Sep 1, 2001 | 03:20 PM
New User
Default Re: What in the hell... (SOHCkordVTEC)
will do.. its kind of hard to trace for me since its not a constant problems it happens here and there..
at different speeds and different rpms
Old Sep 1, 2001 | 04:22 PM
you might want to try an obd-1 conversion while your at it, obdII=ur mods equate to no power increases
Old Sep 1, 2001 | 04:47 PM
New User
what can i take an obd-I off?
actually i think i just searched my own answer lemme see if ive got it
92-95 ecu's have obdI and 96-98 have obdII
so i could take an obdI off a 94 accord and put it in my 96 and be ready to roll?
does that mean i could have spent less money on a 95 kord
and had n obdI stock for stock a better car?
[Modified by Sabastian, 5:51 PM 9/1/2001]
[Modified by Sabastian, 7:44 PM 9/1/2001]
[Modified by Sabastian, 7:52 PM 9/1/2001]
Old Sep 1, 2001 | 06:18 PM
what can i take an obd-II off?
um , no its a lil bit more complex than that, you would need a jumper between both wire harnesses to make it work, but really its just best to do a standalone ecu like tec-II haltech,...etc.... if money was no object of course. Sabastian on a side note, if you were to do EVERYTHING i have done to my car you would be a poor bastard with a low 15 sec boat, just fyi...
Old Sep 1, 2001 | 06:50 PM
New User
well in that case I guess ill have to do somethings different.
ArmaanOG
Jul 23, 2009 03:55 PM
92ehatch
May 19, 2006 07:01 AM
_Endless_
Nov 22, 2002 07:17 PM
rybred
Sep 13, 2002 11:44 AM
SpeedRacer00-667
Oct 30, 2001 03:39 AM
