what engine is this?
Old Nov 17, 2004 | 09:21 AM
d15civ's Avatar
Default what engine is this?
i dnt kno much about accords so bare with me
a "friend" of mine is apparently getting this engine for $2000CA
he says its out of a 96 Accord EX-R (USDM)
as you can see, it says DOHC VTEC on the valve cover.. ive tried telling him accords dont come with vtec. i did a little research and they do, but only the JDM Model. i found a couple that do but they dont say USDM/JDM/etc. i tried zooming in on the tag but no luck, its all blurry
A20A1 2.0 12V SOHC 2bbl Carb 1955 98hp@5500rpm 109tq@3500rpm '87-'89 Accord DX/LX (USA)
A20A3 2.0 12V SOHC PGM-FI 1955 110hp@5500rpm 114tq@4500rpm '87 Accord LX-i (USA)
A20A3 2.0 12V SOHC PGM-FI 1955 120hp@5500rpm ?? '88-'89 Accord LX-i (USA)
BS 2.0 12V SOHC 2bbl Carb 1955 98hp@5500rpm 110tq@3500rpm '86 Accord DX/LX (USA)
BT 2.0 12V SOHC PGM-FI 1955 110hp@5500rpm 114tq@4500rpm '86 Accord LX-i (USA)
C27A4 2.7 24V SOHC PGM-FI 2675 ?? ?? '95 Accord V6
EF1 1.6 8V SOHC 3bbl Carb 1600 68hp@5000rpm 85tq@3000rpm '76-'78 Accord (USA)
EK1 (2V) 1.8 8V SOHC 3bbl Carb 1751 72hp@4500rpm 94tq@3000rpm '79-'81 Accord (USA)
EK1 (4V) 1.8 8V SOHC 3bbl Carb 1751 75hp@4500rpm 96tq@3000rpm '82-'83 Accord (USA)
ES2 1.8 12V SOHC 3bbl Carb 1829 86hp@5800rpm 99tq@3500rpm '84 - '85 Accord (USA)
ES3 1.8 12V SOHC PGM-FI 1829 101hp@5800rpm 108tq@2500rpm '85 Accord SE-i (USA)
F20A 2.0 16V DOHC PGM-FI 1955 150hp@6100rpm 137tq@5000rpm '90-'93 Accord Si (JDM)
F20B 2.0 16V DOHC VTEC PGM-FI 1955 149 kW ?? '90-'93 Accord Si-R (JDM)
F22A1 2.2 SOHC PGM-FI 2156 125hp@5200rpm 137tq@4000rpm '90-'93 Accord (USA)
F22A2 2.2 SOHC VTEC PGM-FI 2156 108 kW ?? '94-'97 Accord EX
F22A4 2.2 16V SOHC PGM-FI 2156 130hp@5200rpm 140tq@4000rpm '90-'91 Accord EX (USA)
F22A6 2.2 16V SOHC PGM-FI 2156 140hp@5600rpm 142tq@5200rpm '91 Accord SE (USA)
'92 Accord EX-R (JDM)
'93 Accord EX/SE (USA)
F22B1 2.2 16V DOHC PGM-FI 2156 145hp@5500rpm 147tq@4500rpm '94-'95 Accord EX (USA)
F22B2 2.2 16V SOHC PGM-FI 2156 130hp@5300rpm 139tq@4200rpm '94-'95 Accord DX/LX (USA)
F23A1 2.3 SOHC VTEC 2259 112 kW '98+ Accord EX/LX
F23A4 2.3 SOHC ULEV VTEC PGM-FI 2259 110 kW ?? '98-'?? Accord EX/LX
H22 2.2 16V DOHC VTEC PGM-FI 2157 190hp@6800rpm 152tq@5500rpm '94-'97 Accord SiR (JDM)
Old Nov 17, 2004 | 09:27 AM
Starrman85's Avatar
Default Re: what engine is this? (d15civ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15civ &raquo;</TD></TR><TR><TD CLASS="quote">[img]
H22 2.2 16V DOHC VTEC PGM-FI 2157 190hp@6800rpm 152tq@5500rpm '94-'97 Accord SiR (JDM) </TD></TR></TABLE>
those are the engines that you have left, that could be it.
Old Nov 17, 2004 | 09:42 AM
kniob's Avatar
the USDM accords indeed did not have any DOHC VTEC engines, but some of the JDM accords did. I don't know the exact code for the engine, but the car is called the Euro-R or SiR if I remember correctly.
Old Nov 17, 2004 | 09:44 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: what engine is this? (STARRMAN85)
actually, you can also eliminate the F22B1 since that is a SOHC VTEC from the 94-97 Accord EX (USDM)
You can probably also eliminate the F20A since it doesn't say it's a VTEC model. Thats is of course providing that info is correct.
Old Nov 17, 2004 | 09:47 AM
Starrman85's Avatar
Default Re: what engine is this? (TouringAccord)
well, in the list i made, i just got rid of all the SOHC engines, wasn't even paying attention to the vtec part =P so there, one less engine to worry about.
so...that leaves what...2 engines? i'd say its probably an h22.
d15civ's Avatar
here's the link to where i got all the info from..
http://www.geocities.com/honda...s.htm
its the most complete chart ive been able to find on the net..
like touringaccord said.. it depends on how acurate it is..
is atleast the $2K mark out of the question, if it does happen to be a JDM accord engine.. im thinking it is, but i could be wrong.. i dont kno what accord engines go for
Old Nov 17, 2004 | 09:58 AM
H-T Order of Merit
there were a couple other mistakes I noticed in that list but that doesn't mean it isn't a good reference. I just prefer to use AD when looking for that kind of data. Here is a link to their list of F series motors.
http://www.accordinglydone.com...ies=F
Old Nov 17, 2004 | 11:04 AM
hawkmgc's Avatar
Odd the list on the site
Does not have the F22A4 listed for the 91 EX models
and mine has that motor. Looked at the ID stamp on the motor
Says only the F22A6 SHOC VTEC
And mine is not the A6 for sure
Old Nov 17, 2004 | 11:15 AM
jmal1919's Avatar
Why not just pull the heat shield off and read the ending code off of the block. That way your friend & you know for sure.
Old Nov 17, 2004 | 11:25 AM
WRS Motorsports's Avatar
Default Re: what engine is this? (jmal1919)
It's an H22A
Old Nov 17, 2004 | 11:46 AM
d15civ's Avatar
all he has is the pic of the engine..
just to show what he is getting..
if we had the engine i would have checked the tag..
Old Nov 17, 2004 | 11:59 AM
kcxtremeaccord's Avatar
FIRST OFF there is no such thing as a accord EX-r(usdm)
no EX-R was made in the united states.
second its a H22a
Old Nov 17, 2004 | 12:06 PM
Morthren's Avatar
Default Re: what engine is this? (WRS Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WRS Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">It's an H22A</TD></TR></TABLE>
Yeah it's an H22a... but it could be from a 95 lude, this guy I work with has a JDM lude import
Old Nov 17, 2004 | 01:51 PM
rudeman85's Avatar
Default Re: what engine is this? (Morthren)
Quote, originally posted by WRS Motorsports »
It's an H22A
yeah...h22a
Old Nov 17, 2004 | 02:22 PM
New Image's Avatar
Default Re: what engine is this? (rudeman85)
It is a 2.2L DOHC VTEC engine. Always verify the engine code stamped on the front left side of the block. Also check the code on the front of the head.
Old Nov 17, 2004 | 04:13 PM
force-fed's Avatar
http://www.accordinglydone.com/
Old Nov 17, 2004 | 04:48 PM
ACC0RD22's Avatar
Default Re: what engine is this? (f22hafler)
guys as said before its an h22a, the only DOHC vtec that will swap into an accord with a black valve cover. the f20b andthe prelude type-s h22(not sure of the number) have blue valve covers. could be from a 93-95 prelude VTEC, but id expect it to be from a JDM accord or lude, there were more distributed there than here. if hes gettin the tranny and ecu with it then 2k canadian is real cheap, if not, then well its about average
Old Nov 17, 2004 | 05:31 PM
jmal1919's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15civ &raquo;</TD></TR><TR><TD CLASS="quote">all he has is the pic of the engine..
if we had the engine i would have checked the tag..</TD></TR></TABLE>
not to be a dick, just ask the seller to remove the heat shield and get a picture of the engine code
Old Nov 17, 2004 | 06:10 PM
Legendaryyaj's Avatar
You are going to get RIPPED bro. Open up your 5th gen manual and READ! It will say our EX models are refferred to as EX-R in Canada. Civic EX's in Canada are Si's while the US Si's are SiR's in Canada.
Canada has a different trim labeling than the U.S.
Old Nov 18, 2004 | 03:29 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22hafler &raquo;</TD></TR><TR><TD CLASS="quote">http://www.accordinglydone.com/</TD></TR></TABLE>
yes, what about it....?
Old Nov 18, 2004 | 04:27 AM
Daniel M.'s Avatar
Default Re: what engine is this? (ACC0RD22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACC0RD22 &raquo;</TD></TR><TR><TD CLASS="quote">. the f20b andthe prelude type-s h22(not sure of the number) have blue valve covers. </TD></TR></TABLE>
Prelude Type S H22 have a red cover!
Old Nov 18, 2004 | 10:20 PM
gluxxxTEG306's Avatar
H22A
Old Nov 19, 2004 | 06:11 PM
92accordexpower's Avatar
Default Re: (gluxxxTEG306)
Definitely H22, and if it is an accord euro R engine, then you are not getting ripped, thats a great price, because it is not the same as an ex. The euro type R has more horsepower than the ones they put in the ludes, and they have LIMITED SLIP DIFFERENTIAL!!! I know someone who took an h22a out of their car to put the accord euro R engine into it, for the horsepower and mostly the tranny. Also, the euro R engine i have seen had a red valve cover.... but that could have been taken from the lude h22, i didn't ask
slayerfromhell212
Dec 29, 2006 10:41 PM
Rishiras
Mar 2, 2006 02:50 PM
rolledthatho
Sep 2, 2005 11:06 AM
kuckimonster2
Feb 22, 2005 07:37 PM
jwogen1
Mar 16, 2004 02:45 PM
