weird problem
Old Mar 9, 2008 | 01:03 PM
deeweezy187's Avatar
Default weird problem
I wanted to know it anybody else is have this problem i already took it to a shop and they cab't figure it out either. While i drive when i step on the gas the car jus revs and feels sluggish. I took it to a shop and they told me it wasn't the clutch they said its fine. Does anybody have a clue of what might be wrong?
Old Mar 9, 2008 | 01:18 PM
johnlear's Avatar
Banned
Default Re: weird problem (deeweezy187)
It's either the clutch slipping or it's wheelspin, I'll let you decide which is the more likely.
Have a another mechanic look at it. If it's manual, and the wheels are on the ground, and it's in gear, and it drives, and it revs without picking up speed then something has to be slipping...
Old Mar 9, 2008 | 02:21 PM
Default Re: weird problem (johnlear)
but if i turn the car on and let it sit for a lil bit it will drive normal and if i step on it and shift the tires still chirp i only had the clutch for not even a year. it doesn't do all the time.
Old Mar 11, 2008 | 02:16 PM
anybody? when its not doing the slipping thing and i drive hard and shift and higher rpms the tires still chirp. Can i bad clutch still do that. What are signs of a bad flywheel? I also notice a chatter sound coming from under my engine bay could this be the cause?
Old Mar 11, 2008 | 05:06 PM
cb7tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deeweezy187 &raquo;</TD></TR><TR><TD CLASS="quote">anybody? when its not doing the slipping thing and i drive hard and shift and higher rpms the tires still chirp. Can i bad clutch still do that. What are signs of a bad flywheel? I also notice a chatter sound coming from under my engine bay could this be the cause?</TD></TR></TABLE>
bad idle sensor fo sho
Alope
Feb 25, 2014 07:29 PM
flytip_21
Aug 27, 2007 04:26 PM
Easyslider01
Honda S2000
44
Dec 12, 2006 04:49 PM
86si
Feb 3, 2006 12:04 PM
dirtysohc79
Sep 13, 2005 04:04 PM
