Vtec?
Old Nov 2, 2010 | 10:23 AM
Ct93CB7's Avatar
Default Vtec?
is it possible to put the head of an 97 honda accord vtec solenoid on the lower half of a 94 accord vtec solenoid just to have a pressure switch or shuld i just try to find the hole solenoid all together.... im running my car wit the obd2 motor on the obd1 ecu but don feel the vtec and got a 22 code..
Old Nov 2, 2010 | 02:17 PM
sony224422's Avatar
Default Re: Vtec?
if you don't have the solenoid, no vtec.
Old Nov 2, 2010 | 11:52 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Vtec?
36171-P0A-015 011 001 SOLENOID ASSY.
Is the same solenoid between '94-'97 F22B1 cars. You should be able to use the '97 solenoid on the '94 switch assembly.
However the lower assembly carries a different part number, possibly a different spool valve.
Old Nov 3, 2010 | 08:50 AM
Ct93CB7's Avatar
Default Re: Vtec?
ill try it n c if it works out hopefully it will
jsmeal04
May 17, 2009 08:23 PM
1sikhatch
Feb 2, 2006 01:40 PM
jmcfkya
Dec 28, 2004 12:14 PM
