Voltage Drop
Old Dec 25, 2011 | 06:44 AM
curtie94's Avatar
Default Voltage Drop
Hi I have been having electrical problems in my 91' Honda Accord. At idle all the lights are dim and the heater blower is slow. But when the gas is applied all the lights and heater get faster. So today I went and checked for voltage drop from the battery. The wire that goes from the battery to the fuse block had -60 milivolts and the the starter wire had -2 millivolts.
SO i'm pretty sure I need a new wire to the fuse block. Is that right.
Old Dec 25, 2011 | 06:56 AM
GhostAccord's Avatar
Default Re: Voltage Drop
Sounds like you have ether a week battery or dead alternator to me.
Not sure how you are getting 0.06v from the battery and the car is still actually starting and running.
Old Dec 25, 2011 | 07:11 AM
curtie94's Avatar
I was checking voltage drop from one side of the wire to the other.
Old Dec 25, 2011 | 07:30 AM
So are you getting a 0.06v drop over the length of the wire going from the battery to the fuse box? If you have 11v-14v from the battery and a drop of 0.06v then I would say your OK on that wire.
Old Dec 25, 2011 | 07:36 AM
curtie94's Avatar
Ok and it was .02 volts to the starter. What I notice is that when the car is revving at about 2000 rpms I get 14 volts but at idle 750rpms I barely get 11 and the alternator puts out 10.5V is there a bad diode in the alternator or does it sound like voltage drop.
Old Dec 25, 2011 | 12:32 PM
curtie94's Avatar
Is there any way to check for a bad diode with the alternator still in the car?
Old Dec 25, 2011 | 12:38 PM
hondawhiz's Avatar
your alternator is bad. or your battery is causing it to seem that way. check your voltage to your power cable while its disconnected from the battery. might need a new battery.
Old Dec 25, 2011 | 04:55 PM
MAD_MIKE's Avatar
MM Gruppe B
Bad diodes would cause a flickering or pulsing of the headlights at night. If the voltage regulator was crapping out or not sensing the correct voltage it would not properly charge. At the battery when then engine is running you should have ~14.4V
Test the battery is fully charged.
12.65V 100% 1.265 g/cm3
12.45V 75% 1.225 g/cm3
12.24V 50% 1.190 g/cm3
12.06V 25% 1.155 g/cm3
11.89 V 0% 1.120 g/cm3
If when fully charged the battery only reads below 12.65 V then it is considered 'dead'.
Old Dec 25, 2011 | 05:04 PM
curtie94's Avatar
What do you mean by that? What are the steps.
Old Dec 25, 2011 | 07:46 PM
nus_dogg's Avatar
He might've mean to OHM test the power wire.
jc95148
11
Dec 21, 2012 08:53 AM
DA6timo
Oct 17, 2009 06:28 PM
philkehn
21
Jul 5, 2006 08:29 PM
EFz6er
Aug 4, 2005 10:29 AM
