Vacuum Problems
Old Nov 22, 2011 | 12:50 PM
K1llaturtl3's Avatar
Default Vacuum Problems
I have a 92 accord that I swapped the head out with a f22b1 v-tec. The car idles fine and has awesome acceleration; until it hits 2500 rpm's. At 2500 the car will stop accelerating and the gas cuts out, but the car will continue running and when I shift into 2nd I can only reach 1500 rpm's the same is for 3rd 4th and 5th. I was looking around and found that my f22a vacuum set up is different than the f22b. has anyone heard of a way to run the vacuums for this swap?
Old Nov 22, 2011 | 07:16 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Vacuum Problems
Old Nov 22, 2011 | 10:28 PM
holmesnmanny's Avatar
Ya, you gotta have ur wiring wrong. Just do a google search for f22b1 and f22a(enter the letter of whatever ur car is here) and reroute the wiring.
Old Nov 23, 2011 | 01:18 AM
All of the wiring is ran correctly, the vacuum hoses are my problem. And I have searched it a million different ways lol
Old Nov 23, 2011 | 10:31 AM
Yeah, I meant vacuum wiring.
Old Nov 23, 2011 | 06:12 PM
ok so I went and looked a friends vtec and I ran the hoses as I seen, but I don't know where hoses 20 and 21 would run to. anyway now I just need to figure out how to make it look sexy lol
Old Nov 23, 2011 | 06:38 PM
v4lu3s's Avatar
RTFM
one vacuum line to the fuel pressure regulator.
the lines coming out of the control box on the firewall....one will go to the egr valve, the others will go to the manifold. thats box has the evap purge solenoid, egr control solenoid and map sensor in it.
and what on earth do you have hooked up to the map sensor on the throttle body? did you cut the plug off the 5th gen harness and splice it on to yours (meaning you moved the map sensor plug from the firewall map sensor and put it on the throttle body one)? is your tps even hooked up?
Old Nov 24, 2011 | 09:58 AM
I used the original harness but on the 92 Accord the map sensor was on my throttle body. lol so yeah its hooked up. But the connection to the fuel pressure regulator comes off the manifold on the 97 and that is hose 24; and 16 goes to the egr valve. I need to know where the connections for 20 and 21 go.
Old Nov 24, 2011 | 01:44 PM
Did you put your throttle body on the 97 IM ?
Old Nov 25, 2011 | 12:19 PM
No I have the complete Throttle body and Intake Manifold from the Vtec. The whole thing is there head is there with an after market header. The O2 sensor is ran to the front of the catalyst. My TPS is plugged into the original harness. The engine harnesses for both cars are all the same; excluding the vtec aspects. I have read that it may be my fuel pump reset switch. IDK where that is though.
Old Nov 25, 2011 | 01:06 PM
v4lu3s's Avatar
RTFM
well if you had a map sensor on your 92 throttle body someone had already done something weird as the map sensor is inside the control box. the control box has teh egr control solenoid, the egr vacuum control valve, the evap purge solenoid and the map sensor.
20 and 21 just need to see a vacuum source from the manifold.
Old Nov 26, 2011 | 02:31 PM
I ran the hoses to the manifold, now I just need to know why I can not accelerate past 1500 rpm's. when I do not have a load on the engine it will redline; but when I shift to first gear and drive away I can only get to 1500 before the fuel pressure bogs out and I have to shift to get it to go again. But if I press the clutch while it bogs out I can rev it up. wierd...
Old Nov 26, 2011 | 03:59 PM
No, he said he used the vtec TB so that's why the map sensor is on the top, it's not the accord one.
Can you take pics of where you ran each vacuum hose and we can help u to route them correctly.
Given u have the same amount of components they should all add up. The hoses themselves should be numbered as long as u didn't take them off the source they should be easy to tell what they go from and to.
Old Nov 26, 2011 | 07:13 PM
bdmlilburn's Avatar
im curious what ecu you are using. though im not the most knowledgeable person when it comes to vtec head swaps and all the wiring stuff that comes with it.
i see the 90-93 map is still in the control box. maybe try the f22a tb on the f22b plenum so that the vacuum lines can be hooked up in their stock location. hose #21 is supposed to be the vacuum hook up for the 90-93 map sensor. 20, 24, cruise control, fuel pressure regulator all go to any open nipple on the upper manifold. and then 16 goes to the egr solenoids which get their vacuum from 24 through the upper manifold
make sure the tps sensor connection is not mixed up with the egr or map, can't remember which but i know two of them are easily mixed
Old Nov 26, 2011 | 10:35 PM
I think you can only swap those two connectors in a 5th gen accord as they are too far away in a 4th gen. I know I couldn't get them to swap in mines.
Old Dec 4, 2011 | 09:09 PM
Yeah I will get pics tomorrow, and post them asap.
I used the ecu out of my 92 the POA, it is the same ecu found in the 94 with the vtec. I just had to run the vtec to two pins. (A4 - VTEC SOL[grn/ylw] & D6 - VTECH PRESSURE SWITCH[blu/blk]). I can also post pics of that to help any one else doing this.
Old Dec 4, 2011 | 11:25 PM
Hey dude, see if it's throwing any codes. Is the check engine light on ? When I just finished my swap, I couldn't get the vtec pressure pin on the connector and when I plugged in the connector it wasn't making contact. It was only a couple weeks or so ago that I realized that the connector can be snapped open for easy assembly for the pin to go onto the connector otherwise it just gets stopped by the thing that opens up. Not sure if this is ur issue or not. My car was throwing a code for vtec pressure switch and the car was in limp mode.
Old Dec 5, 2011 | 11:20 AM
no I was getting an o2 code. I replaced my o2 now but still in limp mode
TylerC161
Jun 30, 2006 11:38 AM
phrasathane
Mar 9, 2004 11:07 AM
11secdx
Oct 9, 2003 08:35 PM
FBPninetynineEM1
Mar 18, 2003 01:24 AM
