unknown problem(s)
Old May 31, 2005 | 10:59 AM
poqbod's Avatar
Default unknown problem(s)
Hello. I'm not especially knowledgeable with this, so I could use some expert opinions. I've got a problem with a '92 Accord LX. 220k miles, clutch a few months ago, smog last month. No major work or mods recently.
The car is shaking/shuddering, particularly while idle, but while moving at lower RPMs too. I can also hear the exhaust from inside the car; a pattering noise that seems much louder/slower than usual. In addition, it has a slight hesitation when starting, as if the battery were low. These problems all started suddenly; first noticed it after getting off the freeway, & parking at home.
Most of this seems to indicate an exhaust problem to me, but I'm more or less a newbie. Anyone experienced something like this, or have any ideas as to what would cause these symptoms? Thank you for any input.
Old May 31, 2005 | 11:59 AM
i20ar's Avatar
Default Re: unknown problem(s) (poqbod)
have you ever changed your air filter?.... and how recently have you changed the spark plugs and you might want to replace your pcv valve located on top of your valve cover. those are some simple things that could help out a bit..i dont know what exactly would cause that
Old May 31, 2005 | 03:37 PM
i20ar's Avatar
it could be your idle air intake valve i think that what its called you might need to adjust it or it could also be that one of your vacume lines is disconnected
Old May 31, 2005 | 08:35 PM
poqbod's Avatar
Default Re: unknown problem(s) (DJ14aZnS)
Thank you very much for the suggestions. I will look into them.
Old May 31, 2005 | 08:59 PM
lilman4o8's Avatar
i would say one of your vacume lines, check all the hoses.
Silveraccord02
Jul 21, 2015 04:42 PM
Project Phoenix
Honda CR-V & Element
Jun 23, 2014 10:30 AM
Teawins21
Aug 26, 2013 10:37 PM
wanting an EF
Mar 2, 2011 07:52 PM
Z-CARR
Nov 1, 2005 08:29 PM
