TPS problems
Old May 1, 2009 | 11:00 AM
akamrmike's Avatar
Default TPS problems
I just put on a new blox tps and adjusted it to .45 closed and it is about 4.4 WOT. I bought this off of ebay so that may be my problem, but after I got it on the check engine light started blinking and when I get ready to take off it studders and won't go past 4,000 rpm. There isn't much problem with it idling misses a little not much. While looking through all of the sensors on ebay some said their's fit all makes for accord others just listed certain years. After looking through quite a few pages It looked like they were all pretty much interchangeable. This is the one I bought http://cgi.ebay.com/ebaymotors/ws/eB...1162&viewitem= It says it is for b/d/h and f series 92-00, I have a 2002, but the 2000 accord should be the same as 2002 they both have same motor and both vtec. Anyways before I e-mail person I bought it from I just wanted to make sure that it wasn't on my end and I wasn't doing something wrong.
Old May 1, 2009 | 09:10 PM
jhondayang's Avatar
Default Re: TPS problems
well, I put a 2000 accord tps on my h22 obd1 throttle body and it works fine. any mil on?
Old May 3, 2009 | 03:45 PM
aasaa666's Avatar
Hi, just letting you know that it is actually .49v closed and 4.5v WOT. So you may want to adjust it first. Then you got to power down the PCM and then do the idle learn procedure. So, try that first before you tell the seller that something is wrong with their product.
TurboTravis
Jan 18, 2018 07:53 PM
pwoodall
Feb 20, 2014 02:03 PM
hondalife75
Jun 5, 2010 07:30 PM
sEa lOS gRill
Feb 15, 2008 06:51 AM
kkittle
Oct 25, 2006 05:36 AM
