Tired Engine
Old Jun 11, 2010 | 03:04 AM
propwdialogue's Avatar
Default Tired Engine
So this may seem obvious, but I figured I'd check. I've got almost 200k on my engine, and it still runs like a champ, most of the time. Recently, it seems to be "running out of breath" in the upper RPM range (5k and above).
Likely causes? Just getting old and tired? Anything I can do?
Old Jun 11, 2010 | 03:22 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Tired Engine
Maintenance?
Plugs, Wires, Air filter, fluids, clean EGR, etc?
If that doesn't seem to help much you could have it taken apart to see if there is wear on the internals more than expected.
Old Jun 11, 2010 | 10:32 AM
YeuEmMaiMai's Avatar
my friend just did the cap and rotors on his accord with 180K on it for the first time......one of he bolts sheard on the distributor cap and the rotor was frozen on the distributor.....took some effort to fix that.....
Old Jun 11, 2010 | 07:39 PM
crx_91si's Avatar
maybe do some kind of intake/injection system cleaning.
At work, we use a product by a company called BG. It's a 3 part system that requires some special tools to perform. It pretty much cleans the intake system, valves and injectors free of carbon and other deposits. It might be worth going to a dealer and paying the $110 (estimated) to have it done. I know the Honda dealer near me uses BG products. I've seen it work wonders first hand with the 1.8t Volkswagen's, and those things are the biggest POS's when they get up past 100k miles.
Not trying to be a salesman for this product, it's just a thought.
good luck
mike
axfireinside
Jul 31, 2012 08:26 PM
carlosg7915
Aug 2, 2011 06:59 AM
enigma2446
Jul 20, 2011 10:28 AM
m1ndless
Nov 30, 2007 11:31 PM
dj schnitzler
Jun 27, 2006 01:32 PM
