Timing Issues
Old May 24, 2018 | 06:21 PM
diptator's Avatar
Default Timing Issues
Hey guys!
I'm having timing issues with my 1996 honda accord lx with the 2.2L Non-Vtec engine and Obd2. I recently did the timing belt job on my car doing the front balance shaft seal, camshaft seal, water pump, tensioners and timing and balance shaft belts. Recently, using a basic, non adjustable timing light, I have been finding that my timing has been off about 15 degrees behind on the crankshaft pulley, I have tried adjusting the timing, and triple checking that my camshaft and crankshaft are lined up in TDC and the timing light continues to show that the timing has been off. I've concluded then that it may be the ignition timing that may be off but I have found nothing in order to fix that. Also I'll include that I followed TouringAccords tutorial to the teeth, and the timing continues to be off.
If any of you guys have any thoughts, tips, or questions, please let me know. Any input is much appreciated.
Thanks guys!
Old May 24, 2018 | 08:27 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Timing Issues
Originally Posted by diptator
Hey guys!
Thanks guys!
Are you sure the inductive pickup is installed correctly on the spark plug wire? If you have the pickup on backwards it will show the incorrect timing.
Beg/Borrow/Steal another timing light and recheck.
Since the timing light has no adjustment, and the crank pulley only has the marks for TDC(white) and base timing(red), how do you know the timing is 15° ATDC?
Old May 24, 2018 | 08:59 PM
diptator's Avatar
I'm pretty certain its installed correctly, however I could be wrong. The procedure is pretty simple for it is pretty simple. I'm not entirely sure how to describe how off the timing is aside from that the set of three marks on the crankshaft pulley are chilling about an inch or two away from the timing mark on the side cover and in the direction towards the rear of the car. The 15 degrees is a rough estimate.
Old May 24, 2018 | 09:23 PM
MAD_MIKE's Avatar
MM Gruppe B
Inductive pickup should have an arrow indicating which way it should be. Usually 'PLUG ==>' will be on the pickup to show which way it should be facing.
I would try another timing light to confirm, a decent whack can damage them.
How does the engine run? Is it lazy? Or does it seem to run fine?
Are you sure the outer ring of the pulley has not slipped?
Old May 25, 2018 | 09:38 AM
diptator's Avatar
I'll try and get my hands on another timing light today. The engine runs fairly okay, I would say more on the rough side, you can hear a faint misfire coming from the exhaust. And the outer ring of the crank pulley has not slipped same with the cam pulley.
lsegcoupe
Dec 22, 2006 07:54 PM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
slowassgsxr750
Jan 11, 2003 10:23 AM
