Things to replace before alignment.
Old Feb 2, 2010 | 03:51 AM
JigsN Joints's Avatar
Default Things to replace before alignment.
Ok so i am replacing my front driverside axle because im led to believe my cv joints are shot..
What are some other things i should replace in the front end before i go get new tires and an alignment
Old Feb 2, 2010 | 04:37 AM
nus_dogg's Avatar
Default Re: Things to replace before alignment.
Is your car lowered?
Old Feb 2, 2010 | 05:50 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
If it ain't broke don't replace it.
If it is, tie rod (outer/inner)
ball joints upper or lower.
Or if there are any bent parts.
Old Feb 2, 2010 | 12:14 PM
Sorcerer's Avatar
especially if you're buying some cheap chinese remufactured CV's
I've been through a nightmare of vibration issues and clunking from garbage CV axles...
Buy Raxles or buy factory axles from a JDM importer. If it doesn't have a balancer bushing don't put it on your car!
Old Feb 2, 2010 | 01:14 PM
TheMuffinMan's Avatar
He knows where you live!
Why on earth would you suggest buying unknown condition used OEM axles from an importer? You are 10,000 times better off purchasing new OEM from the dealer.
Several users have 300+ hp to the wheels and are using new OEM axles without issue.
Old Feb 3, 2010 | 06:51 AM
shortlid's Avatar
Tierods were looking tired on my '99 with 160k I put Moog problem solvers on both sides with grease nipples for $40 before I got a alignment.
Another question with our double wishbone front suspension do you HAVE to re-align the car after front strut replacment??
Old Feb 3, 2010 | 09:23 AM
After replacing the struts I would recommend it. Just because you're loosening up all those components and risk wiggling them. Something like a sway bar I'd be less concerned about.
Assuming you're doing a stock for stock replacement the difference/change would be minimal (hopefully) but for optimal tire life you probably want to have it double checked.
Old Feb 4, 2010 | 10:21 AM
shortlid's Avatar
Thanks, do I HAVE to take the ball joints apart to put new struts in?
Freefallin99
Honda CR-V & Element
Mar 14, 2017 11:16 AM
Swansen
Transmission & Drivetrain
Jan 29, 2016 07:26 AM
hazeleyes76
Nov 23, 2007 07:04 PM
realityplusprof
Aug 28, 2004 04:07 AM
G1 TEGGY
Aug 17, 2004 04:34 PM
