temperature sensor
Old Jan 18, 2006 | 02:32 PM
Dilly's Avatar
Default temperature sensor
i have this 92' ex accord...actually its my moms, but anyway. it hasn't been turned on for about 2 months or something. about 3 days ago, i started it up and the temperature gauge needle was on the "H". then roughly about a minute or 2, it went towards the middle a bit then went up again. is it just the sensor being retarder and freaking out?
Old Jan 18, 2006 | 05:18 PM
hondadude's Avatar
Default Re: temperature sensor (dillywong)
This sounds like the temp sensor is going south, it is a single wire connector in the head under the dist. the way to test it is to unhook the connection, then turn on the ignition..gauge should stay low; then ground the wire and the gauge should start heading to hot. Don't leave it grounded too long you don't want to 'peg' the gauge. If things don't work as described, the guage may be at fault.
Old Jan 18, 2006 | 05:22 PM
hondadude's Avatar
Blame the double post on "flood protection"
Old Jan 18, 2006 | 07:15 PM
Honda-Master's Avatar
also try this .......take wire out of temp sending unit.. put key on and start car,, if temp gauge goes to hot , you got a wire shorted to ground or a bad gauge///........
I have seen a few bad gauges ..
Old Jan 18, 2006 | 10:05 PM
iam7head's Avatar
Default Re: (Honda-Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Master &raquo;</TD></TR><TR><TD CLASS="quote"> also try this .......take wire out of temp sending unit.. put key on and start car,, if temp gauge goes to hot , you got a wire shorted to ground or a bad gauge///........
I have seen a few bad gauges ..</TD></TR></TABLE>
could be, but i would test the wires from the sensor first, i think it's the yellow green wire in the bay, it should read 6volt after warm up/driving temp
dejay2014
May 16, 2014 02:36 PM
hondaaccordf23
Jul 30, 2012 12:24 AM
k.gren
12
Nov 1, 2011 09:18 AM
lilmarcEH3
May 20, 2010 05:25 PM
eth0r
Nov 10, 2005 03:31 AM
