stroke of bad luck
Old Dec 10, 2012 | 03:01 PM
KINGFLIP's Avatar
Default stroke of bad luck
a few nights ago i was driving home from work, i had to take a detour home because there was some highway work going on, now this particular road that i drove on has almost no lights at all, so it can be hard to see.
Unfortunately, it was raining that night so it made it even harder to see. to my luck, i ended up hitting a huge pothole filled with water. immediately after, my car began to shake violently, i instantly knew it was a bent rim. lastnight, a found a posting on craigslist about a guy sellling some 17" rims and they fit my car, he was selling them for $200. so i went checked them out, and bought them, they seemed fine. i drove with them for the day, and they worked great.
woke up this morning to find that two of the wheels were completely flat. i took them off and noticed 1 rim had a crack in the spoke where it meets the lip and another one had 2 cracks on the back of it, they are very small, but noticible. i dont have the cash to replace them, so my question is, could you weld the affected areas? i've heard about people doing it and succeding, but im a bit skeptical
Old Dec 10, 2012 | 07:18 PM
arkangel2487's Avatar
Default Re: stroke of bad luck
You could weld it but I wouldn't recommend it. You don't really know if the crack was from a bad casting. The weld can actually make the surrounding areas weaker too
Old Dec 11, 2012 | 07:28 PM
MAD_MIKE's Avatar
MM Gruppe B
Rims are consumables.
If they are cracked in one spot, they are bound to crack in another. If the rim was cast it may not be weldable.
Just chuck them and get a new set of wheels or used set of stock wheels.
Old Dec 12, 2012 | 12:11 AM
bairdandrew77's Avatar
If you're too low on money, you might need to use 2 of your old wheels and your 2 newer ones for a bit... A bit ghetto, but I'd do that over taking chances with weld mending wheels
loki2323
May 5, 2015 12:50 PM
G2_Fella
Southern California
17
Jun 7, 2010 03:37 PM
99civicsiboosted
13
Feb 5, 2009 11:20 PM
EF_LEGOMAN
Dec 27, 2005 05:07 PM
