Starting problems
Old Jan 28, 2008 | 06:23 PM
Buddhamania's Avatar
Default Starting problems
I have a 97 accord all stock with 4banger automatic. The problem I have is trying to start it after a good hard rain or when its muggy outside. It cranks over and over but wont start. Its getting gas, cause you can smell it, and its getting fire to it, but I cant figure it out. Its almost like on the older cars with distrubtor caps, like its wet under there. It only happens when it rains or is muggy thats what is throwing me off. Any suggestions would be appreciated. I have checked the wires, connections, and the coils and I see no visible problems or cracks or tears or anything of that nature on em.
Thanks for looking at my thread
Buddha
Old Jan 28, 2008 | 06:35 PM
lostshootingstar's Avatar
Try starting simple and replace your Distributor cap and rotor. If it only happens when its damp out, that would lead me to assume its some kind of ignition problem.
Old Feb 4, 2008 | 01:09 PM
Ronin1's Avatar
Default Re: Starting problems (Buddhamania)
How old are the plug wires, distrib rotor & cap and so on? It sounds as though something like that needs replacing. You can visually inspect them or, if you are more adventurous, run your hand down the wires while the engine is running to see if there are any "leaks". Taking a look while the engine is running at night (in the dark) will sometimes show an electrical glow/leak. Don't forget the plugs while you are at it.
Cheers
mabrewer011
Jan 9, 2014 05:51 PM
fortyfacemohwhat
Oct 17, 2008 05:40 PM
nickmcpher
Aug 21, 2008 05:10 PM
dmj
Feb 23, 2008 03:15 PM
sykotic
Sep 27, 2004 06:15 PM
