starting problem
Old May 12, 2007 | 08:55 PM
alfamotorhd's Avatar
Default starting problem
98 accord ex 4cyl. Can't seem to get ign to fire. If I crank it & crank it(the starter is fine) it will start and run great forever, shut it of and it doesn't want to start. It has good fuel pressure. Have changed coil, icm, dist, plugs & wires, has new cap & rotor.and the main relay is newer,less than a year. The sensers behind the botttom pulley check good on ohms & aren't grounding out. Gets volts to coil with key on and when cranking. i dont know what else to do, HELP !!!!!
Modified by alfamotorhd at 8:09 AM 5/13/2007
Modified by alfamotorhd at 8:15 AM 5/13/2007
Modified by alfamotorhd at 8:17 AM 5/13/2007
Old May 13, 2007 | 06:44 AM
gulfview's Avatar
Default Re: starting problem (alfamotorhd)
The electrical part of the ignition switch may be cutting in and out.
The safety interlock for the transmission?
The main starter relay acting up?
Worn out starter?
Old May 13, 2007 | 09:48 AM
hondadude's Avatar
after you crank it and crank it pull out the spark plugs and look for flooded condition. wet plug.
any codes stored?
Try holding 1/2 throttle to see if it makes a difference
Old May 13, 2007 | 07:34 PM
Default Re: starting problem (hondadude)
Holding throttle open seems to make it to rich, you can smell gas bad , plugs don't seem to be fouled- no codes are stored
EFS463
Aug 14, 2013 05:10 PM
kris9
10
May 27, 2013 03:35 PM
chrisff521
36
Oct 20, 2012 11:28 AM
PhantomX
Apr 6, 2008 09:15 AM
joblow
Feb 20, 2003 09:18 AM
