SQUEEEK!!!!!!!!
Old Nov 29, 2006 | 05:13 PM
SlowPokeEg's Avatar
Mike Jones
Default SQUEEEK!!!!!!!!
Ok, i'm sure it's been covered somewhere/sometime, but i have NO how to search it and i don't frequent this forum but here goes...
91 Accord. The suspension and steering both squeek to high frickin heaven. Are there grease fittings on that model or somethin because it's driving me nuts lol.
I heard another Accord at school, newer model, doing the same thing so i hope it's fixable. It's my winter car so i'm not stressing over it, only annoying.
Thanks Accord owners!
Old Nov 29, 2006 | 06:07 PM
mrhonda2u's Avatar
Default Re: SQUEEEK!!!!!!!! (SlowPokeEg)
could be as simple as sway bar bushings need lubed? sway bar links dry or broken? those accords (90-93) are known for broken front coil springs also (heavy spring around shock) possibly upper control arms bushings? start squirtin' the lube, troubleshoot area. have someone press up and down on suspension to narrow down area.
Old Nov 29, 2006 | 09:06 PM
SlowPokeEg's Avatar
Mike Jones
Default Re: SQUEEEK!!!!!!!! (mrhonda2u)
OK, but do you know if those models have grease fittings or just slab some lube on the joints/bushings?!?!
Old Nov 30, 2006 | 07:36 PM
SlowPokeEg's Avatar
Mike Jones
Somebody must know? I just want to know what to expect when i get some time to run to the Lube Stop
Old Dec 1, 2006 | 04:01 AM
mrhonda2u's Avatar
sorry i"m only a trial user currently. they are not grease fittings. just remove center bushings on sway bar, take out of bracket. lube inside and out and remount on car. that would be if your able to get on a lift. otherwise look for broken coil springs too. turn wheel completly right and look at botton rungs for spring. are they still good? or rusted and broke? that can squeak. also upper control arms mount in upper portion of front fenders inside. have 2 mounts that have rubber bushings. spray silicone spray or like to try and eliminate areas. good luck
AFAccord
Nov 29, 2005 07:36 PM
First Honda 1976
Apr 13, 2004 11:31 AM
abeaujuin
Nov 12, 2003 06:55 AM
tommyg
Feb 15, 2003 04:56 PM
chili
Aug 7, 2002 01:34 PM
