sprayed my engine...
Old May 12, 2007 | 11:58 PM
jonathanraycamacho's Avatar
Default sprayed my engine...
is it ok to clean the engine of grease if used simplegreen and then washed it down with water. im not gonna start it up until it completly dries though... im just asking if that was wise....
Old May 13, 2007 | 12:02 AM
SuShiBoiiii's Avatar
Default Re: sprayed my engine... (jonathanraycamacho)
if you were to do i would leave the engine on if your going to spray it down cover up alternator, bat, fuse box
Old May 13, 2007 | 07:49 AM
The-Kid's Avatar
Default Re: sprayed my engine... (SuShiBoiiii)
Its cool. I do an extra step. I took compress air or even a blower and blow all the water out of the tiny holes
Old May 13, 2007 | 09:50 AM
hondadude's Avatar
put a piece of duct tape around the base of the dist. cap
Old May 13, 2007 | 07:03 PM
hondadude's Avatar
Default Re: (Evil Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Monkey &raquo;</TD></TR><TR><TD CLASS="quote">i pressure was my engine on a regular basis with the engine running and no bags or anything.
Do you really think your engine stays dry while driving in the rain?</TD></TR></TABLE>
It Sure Does; unless you drive around with your hood up LOL
Old May 13, 2007 | 08:15 PM
mine does rofl
Old May 13, 2007 | 08:21 PM
Alpinestar03's Avatar
^ x2.
Old May 13, 2007 | 08:27 PM
cambopheonix56's Avatar
Default Re: (SuShiBoiiii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">mine does rofl </TD></TR></TABLE>
Old May 13, 2007 | 08:52 PM
lowered94accord's Avatar
first off...you shouldnt spray cold water on your motor while its running especially if its up to running temps..that could easily crack the block if its hot enough not to mention do other damage...when I do mine..I let it get fairly cool...whatever engine degreaser brand you buy just read the bottle...some say you dont have to cover anything and some say you do..some say to use when the engine is warm and some say to use and a cool engine...just depends..I bought the black magic or w/e engine degreaser + shine...you use it on a warm engine and dont have to cover anything up..let it set for 20 minutes and rinse with a steady stream of water..did an awesome job...also...how would your engine get wet when it rains? what do you think a hood is for? not to mention splash guards?
Old May 13, 2007 | 09:20 PM
YeuEmMaiMai's Avatar
i wash it while it is off. never had it not start right up after it was washed.
Old May 14, 2007 | 03:34 AM
BlkChryKord's Avatar
I powerwashed mine a few weeks ago w/ nothing covered & cold, started right up.
Old May 14, 2007 | 05:50 PM
Blamm!!'s Avatar
Default Re: (BlkChryKord)
I have power washed my motor countless times and gotten basically all components wet with out problems. Just dont blast directly onto the dist. or fusebox.
tbonez
Honda Civic (2006 - 2015)
Dec 7, 2010 09:44 AM
civycoop
13
Jan 9, 2007 11:00 AM
Pikachu
Nov 25, 2003 11:52 AM
blah13
Apr 16, 2003 09:45 AM
