Spiratic Code 71?
Old Aug 26, 2004 | 10:00 AM
Schmitey's Avatar
Default Spiratic Code 71?
Got a 96 Accord EX w/5 spd. Driving from KC to Columbus I got a couple check engine lights. Pulled the code (71 is misfire in cyl. 1 I believe), reset it, let it idle then kept driving. A few hours later it does it again.
The car is obviously not misfiring. Still ran great and when i felt the exhaust it was putting out like a strong four banger. This happened to me once before and I did an OBD2 scan at Advanced auto. They said it only misfired for two or three cycles.
I'm thinking it's gotta be a bad spark plug or something electrical. I'm still getting excelent gas mileage with plenty of power. Rotor and cap looks good near as I can tell, wires are old but still in good shape. Next step will probably be to get some NGK copper plugs and see if that keeps the code from reappearing. I should mention that it was like two months between the first code and the recent two.
Anything else you can think of that I should check out?
Old Aug 26, 2004 | 11:19 AM
notoriousB's Avatar
Default Re: Spiratic Code 71? (Schmitey)
have you checked the condition of the plugs (esp. cylinder 1)? That will tell you a lot.
I'd recommend a compression test to ensure the motor's still in good shape.
I get a misfire on cylinder 3 all the time, and that cylinder's at ~50% compression.
InTeGrA GsR 321
Aug 25, 2005 05:10 AM
EK_vzla
Aug 30, 2004 01:39 PM
dcaccord
Jul 21, 2003 09:15 PM
reVVin
Mar 31, 2002 07:03 PM
