Speed Sensor
Old Nov 16, 2010 | 02:35 PM
Rat Rod's Avatar
Default Speed Sensor
On a 1990 accord besides causing the Speedometer to stop working what else will a non working Speed Sensor cause your vehicle to do or not do properly.
Old Nov 16, 2010 | 02:44 PM
tamadrummer1120's Avatar
Default Re: Speed Sensor
If the gauge cluster is actually not functioning correctly, that will cause no speed to appear. The 94-97 accords are famous for this issue. Not sure about the 4th gen accords though. And if it is a faulty VSS, the CEL should come on telling you this. And a lot of systems do rely on the VSS, so I believe the car will go into limp-mode, but do nto quote me on that. Definitely will not run efficiently though, as the computer has no idea what speed the vehicle is moving.
Old Nov 16, 2010 | 03:35 PM
Rat Rod's Avatar
Thanks i figured that. the code 17 came on like 3 weeks ago on the ecu which is speed sensor of course. Im not to worried about how fast im going because i just keep up with traffic but i just wanted to make sure it was not going to do any transmission damage until i purchase the new one. Or will it?
Old Nov 16, 2010 | 05:11 PM
its a manual right?
Old Nov 16, 2010 | 07:18 PM
Rat Rod's Avatar
yes. y do u ask?
Old Nov 17, 2010 | 04:35 PM
because no trans damage will happen really with a vss that is broken on a manual trans. automatic could. because the ecu and tcu are monitoring the vehicle speed, engine speed, engine load, ect. as to when to shift. where as on the manual, obviously, you decide.
Old Nov 17, 2010 | 06:22 PM
Rat Rod's Avatar
ok thanks
Old Nov 18, 2010 | 04:02 PM
fleetw00d's Avatar
Bad VSS will also cause cruise control and odometer not to work. If either of those work, VSS is ok and problem is elsewhere (I had a problem with corrosion on the printed circuit board in the cluster).
fcm
Nov 4, 2014 05:32 PM
blaze.1
Sep 10, 2009 06:24 AM
aziaticvang
Jan 13, 2008 06:35 PM
turismo128
Sep 27, 2005 03:22 PM
aws140
Aug 17, 2005 07:08 PM
