Solid transmission mount
Old Sep 9, 2007 | 06:33 PM
fastazzf22's Avatar
Default Solid transmission mount
95 accord coupe. F22b1 w/ 5spd.
I made the original oem transmission mount solid , by griding the rubber away and attaching 2 plates on each side of the mount. Welding the plates to the center brace sleeve also welding the 2 plates to the mount it's self. Making the motor mount completely solid. After taking the car for its first test drive, I hear a hell of alot of noise. Noise that doesnt sound good to me, you can hear the clutch spinning when the pedal is not pressed. Depress the pedal and the noise goes away. Upon acceration there is a slight whining noise. I feel more vibration in the steering wheel upon accerlation at low rpm. Which I thought was normal for a solid mount.
Anyone using a solid motor mount on the transmission and getting similar feedback from the transmission?
I will add that this transmission is brand new from honda dealership. with about 7k hard driven miles.
Old Sep 10, 2007 | 12:51 PM
fastazzf22's Avatar
Default Re: Solid transmission mount (fastazzf22)
ttttt
Mishako129
Mar 8, 2014 09:35 PM
WhiteOnRice
Dec 12, 2006 02:14 PM
DonPapadapolis
Apr 24, 2004 04:06 PM
JoeyBallzSI
Oct 10, 2003 08:24 AM
