95 accord raspy noise under hood
Old 04-11-2016, 04:42 PM
RicerJake's Avatar
Default 95 accord raspy noise under hood
Hey guys, so I drive a 95 Honda Accord ex automatic. My vss just went out and to replace it I had to remove my could air intake. Once I got everything back together my car started making a funky noise like its sucking in air, it sounds different than it did before I took everything off and re did it. It's a raspy noise that only happens when I accelerate. I pulled off my intake checked it and reassembled it. Everything looks right but it's still making that aweful noise. Any ideas on what it could be?
Old 04-11-2016, 07:14 PM
holmesnmanny's Avatar
Default Re: 95 accord raspy noise under hood
its likely normal noise the intake makes when the throttle plate is opened, you just never noticed it before
Old 04-11-2016, 08:20 PM
RicerJake's Avatar
I was actually just checking it out and it looks like my headers have a pretty fat leak in them. I think the noise I'm hearing is a combination of them both. Any recommendations on header/ exhaust setups to run?
Old 04-11-2016, 10:23 PM
It looks like rockauto carries two different options, I would go with the Dorman. Have you verified that the issue isn't simply an exhaust manifold gasket leak ?
rickiroch
04-14-2017 04:31 PM
rickiroch
04-10-2017 10:33 AM
steelcitytim
11-05-2009 08:41 AM
ddolezal
03-30-2008 11:03 AM
kaliATR
03-29-2007 01:52 PM
Quick Reply: 95 accord raspy noise under hood
