Shaking problem please help
Old Jan 7, 2005 | 06:56 PM
e36Mpower's Avatar
Default Shaking problem please help
i have a 93 honda accord and when i brake at high speeds the steering wheel shakes. i can feel it at lower speeds but not as bad. its not the brakes so idk what it is..anything will help thanks
Old Jan 7, 2005 | 07:03 PM
jb.'s Avatar
jb.
Default Re: Shaking problem please help (e36Mpower)
you probably need new pads and rotors because the rotors are warped
Old Jan 7, 2005 | 07:20 PM
gaydm.accord's Avatar
resurface rotors, or just buy new ones. rotate your tires and get wheels balanced.
and yea check out your pads
Old Jan 7, 2005 | 07:23 PM
alotawatts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e36Mpower &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 honda accord and when i brake at high speeds the steering wheel shakes. i can feel it at lower speeds but not as bad. its not the brakes so idk what it is..anything will help thanks</TD></TR></TABLE>
Warped disc rotors will pulsate.....a shake in the steering could be tire, rims, alignment etc. Like jbkiksass69 said...start with a brake check.
Old Jan 8, 2005 | 08:16 AM
Chris W.'s Avatar
Default Re: Shaking problem please help (alotawatts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts &raquo;</TD></TR><TR><TD CLASS="quote">
Warped disc rotors will pulsate.....a shake in the steering could be tire, rims, alignment etc. Like jbkiksass69 said...start with a brake check. </TD></TR></TABLE>
agreed
Old Jan 8, 2005 | 11:04 AM
edd001's Avatar
wrapped discs for definate, if tyre related you would get it any time not just when you break.
baaao
Acura TL, RL & ZDX
11
Nov 13, 2008 02:03 PM
7panget
11
Apr 29, 2008 12:02 PM
globy123
16
Aug 21, 2007 05:23 PM
WalkerGSR1
Suspension & Brakes
Aug 13, 2006 02:36 PM
bren1339
16
Oct 15, 2003 01:08 PM
