setting timing
Old Jul 7, 2002 | 12:09 PM
Hybrid's Avatar
Default setting timing
Are the wires which you connect to set the timing on a late model sohc accord down where the ecu is? Same as say a civic?
Pal of mine just turboed one and was wondering where the wires were too so he could set the timing.
Old Jul 7, 2002 | 01:45 PM
CD8's Avatar
CD8
Default Re: setting timing (Hybrid)
you usually either adjust the timing with a timing gun, or that one apex'i (or is it hks?) electronic timing controller(ETC). you hook the timing gun up to one of the spark plug wires. if your friend has an OBD2 car then he cant adjust the timing with out the ETC.
Old Jul 7, 2002 | 01:54 PM
Accord94DX's Avatar
apexi itc.
Old Jul 7, 2002 | 02:02 PM
CD8's Avatar
CD8
Default Re: setting timing (Accord94DX)
thank you
Old Jul 8, 2002 | 11:16 AM
TWG's Avatar
TWG
Default Re: setting timing (exaccord)
It's actually APEXi SITC... I own one...
Old Jul 8, 2002 | 03:47 PM
urbanlegend21's Avatar
New User
Default Re: setting timing (TWG)
to set the timing with a gun clamp one end to the first cylinders spark plug wire and ground the other one
there is a mark on your crankshaft pulley that will line up with an indicator protruding from the side of the block each time the light flashes, this is if the car is timed at 0 degrees TDC
it has been a while from the last time I have done it ( we usually run 100 octane fuel in the race car and crank the timing all the way up)
efjones9
Aug 7, 2010 10:35 AM
MKIIISupra
Aug 7, 2005 04:38 PM
ewn1603
Sep 25, 2004 06:22 AM
type Gendy
May 18, 2003 02:53 PM
