"S" code and "CEL" For Speedometer, Odometer and Tripometer (THEY DON'T WORK!)
Old Sep 7, 2012 | 05:33 AM
Mishako129's Avatar
Default "S" code and "CEL" For Speedometer, Odometer and Tripometer (THEY DON'T WORK!)
Its a newly rebuild motor with a low mileage JDM AT. The speed sensor is good for sure because I tested it with a new one that I ordered for my old trans.
So it can't be the VSS.
I was discussing on another forum some possiblities, but I don't want to mention them because you may already know what's causing this.
I think the cruise control works, the light comes on but I have never used it b/c I am breaking in a rebuilt engine (first time).
Please help, this is one of the worse things that could happen for a newly rebuilt engine. I need to know my speed and I need to know how many miles I am going.
TY
EDIT,
Its puling a CEL 17 code (VSS) and a S light 4 code (same thing, VSS)
Old Sep 7, 2012 | 11:56 AM
Mishako129's Avatar
Default Re: "S" code and "CEL" For Speedometer, Odometer and Tripometer (THEY DON'T WORK!)
bump it up
Old Sep 7, 2012 | 12:48 PM
Mishako129's Avatar
I discovered that one of the pins for the adapter on the wiring harness is partially missing or broken off. I tried to put some aluminum foil in there and a paperclip but it keeps giving codes.
How do i fix this broken pin?
Old Sep 7, 2012 | 09:55 PM
MAD_MIKE's Avatar
MM Gruppe B
Not sure which pin or connector you need. Sumitomo, and Tyco are both the OEMS for those parts, Honda does sell some of those pins with a length of wire but are in the ~$30 range.
http://www.hondaautomotiveparts.com/...TORS+%28FR.%29
Check out this site, hell even if you buy 10 different pins you are still only in it for 3 bucks
http://www.bmotorsports.com/shop/pro...oducts_id/1783
Or just cut a pigtail off a yard car.
mostwanted_ek
Apr 25, 2018 03:58 AM
Japankid
Apr 7, 2009 01:45 PM
PyroProblem
May 8, 2007 06:20 PM
nelson69
Oct 30, 2005 05:13 AM
Kaan
Sep 26, 2005 11:31 PM
