Replacing cabin (A/C) filter
Old Aug 4, 2004 | 05:49 PM
teamguerino's Avatar
Default Replacing cabin (A/C) filter
My '01 Accord just hit 30,000 miles and the owners manual lists replacement of the cabin filter as one of the standard items to take care of. I have absolutely zero desire to take it to a dealer and pay through my nose for this service, but of course the manual doesn't say how.
Is it really complicated? Any tips on how to proceed if I want to change it myself?
Thanks.
Old Aug 4, 2004 | 06:11 PM
Chiovnidca's Avatar
Default Re: Replacing cabin (A/C) filter (teamguerino)
You have to take out the glove box. It's behind it.
Old Aug 4, 2004 | 07:02 PM
cmrvi1's Avatar
If you've never done one, expect to spend about 20 minutes.
Here's the procedure as I do it at the dealership.
1) Remove side cover on right side of dash, and remove 2 screws holding right side lower dash cover.
2) Remove cover located in console pocket in front of shifter, and remove right side screw.
3) Remove lower dashboard cover.
4) Open glove box and removes covers on both upper corners. Remove screws behind covers and 2 screws holding latch.
5) Remove 4 screws holding glove compartment at the bottom, and pull glove box up and out. Disconnect glove light connector.
6) Remove 4 screws holding upper stiffening bar and remove bar.
7) Remove 2 screws holding lower stiffening bar and remove bar.
8) Finally, snap cover off evaporator case and remove both filters.
Installation is in reverse order.
Modified by cmrvi1 at 9:55 PM 8/5/2004
Old Aug 5, 2004 | 05:37 AM
JimBlake's Avatar
Default Re: Replacing cabin (cmrvi1)
... and pay attention to the filters you take out. There's an arrow showing the direction of air flow.
Old Aug 5, 2004 | 07:30 AM
That sounds like a lot of work to get to a filter, but it beats selling of a kid or getting a second mortgage to have someone else do it! Thanks for the instructions. I'll give it a go myself.
Old Aug 5, 2004 | 09:01 AM
Elvis1977's Avatar
Is it REALLY necessary to replace these filters every 30k? The two filters cost 35 bucks. That can get expensive over time.
Old Aug 5, 2004 | 09:38 AM
JimBlake's Avatar
Default Re: Replacing cabin (Elvis1977)
I've owned a few cars that didn't even have a cabin air filter, & I survived... So if it's really bad you could just throw it away. How about some of those discount mail-order parts places? I think I got mine at ManHonda.com for cheaper than that.
When I changed 'em, I was surprised how dirty they were.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamguerino &raquo;</TD></TR><TR><TD CLASS="quote">... beats selling of a kid...</TD></TR></TABLE>hmmmm.... maybe then I wouldn't have to pay for 2 colleges
Old Aug 5, 2004 | 01:06 PM
Grumpy611's Avatar
I just replaced the cabin filters on my 01 accord atr 30,000 miles-it was actually easier than I thought!
I found the below link to be very helpful, with an especially good tip on removing some of the highly torqued screws you may encounter:
http://www.autowhiz.com/messag...d=487
This link has some good pictures to use as a guide:
http://www.troublecodes.net/ar...shtml
Lastly, a good overview of the entire process, again with lots of pics:
http://autorepair.about.com/li...g.htm
FYI, when I removed the filters, they were black!
Good luck to you.
Old Aug 5, 2004 | 01:54 PM
Vic Nyce's Avatar
Default Re: Replacing cabin (Grumpy611)
does a 96 accord have a cabin filter too??
Old Aug 5, 2004 | 02:52 PM
Chiovnidca's Avatar
Default Re: Replacing cabin (Vic Nyce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vic Nyce &raquo;</TD></TR><TR><TD CLASS="quote">does a 96 accord have a cabin filter too??</TD></TR></TABLE>
Nope, 98 and up on Accords.
Old Aug 5, 2004 | 03:16 PM
b18crx's Avatar
does the 98 lx accord even have this filter? dont think i have the books to check. accords are new to me as well. the car has like 193k so i'd replace if it does have.
thanks .
o2sI
Nov 14, 2004 12:18 PM
b18bvtec4drteg
Acura TL, RL & ZDX
Mar 30, 2004 07:28 PM
01-1293
Mar 31, 2002 08:38 PM
charjacq
10
Feb 16, 2002 07:23 AM
