Remote start problems
Old Jul 27, 2004 | 10:21 PM
BigSlim's Avatar
Default Remote start problems
I have a 97 accord lx with an after market remote starter w/pager. Not sure of the brand name anymore. Just received my car from the shipping company, and now when I remote start it, it keeps cutting off after 3 unsucessful tries. I dont know if its not idling right or what. But I never had this problem with the Viper 550esp. Can anyone help?
Old Jul 27, 2004 | 10:49 PM
StopChek's Avatar
Default Re: Remote start problems (BigSlim)
I duno if its the brand or not cuz i also have a viper brand. It works fine and i got it long time ago. My only idea is that you take it bak to where you installed it and ask whoever installed it for you.
Old Jul 27, 2004 | 11:17 PM
BigSlim's Avatar
Default Re: Remote start problems (gotmilk80)
only if it was that simple, i live in spain now, the alarm was installed in cali.
Old Jul 28, 2004 | 04:20 AM
Mike813's Avatar
my car would take like 2 tries sometimes to crank it over with the remote start...
but if i manually go into the car and start it, it works perfectly fine with no choke... i think it has something to do with the alarm, but seems like after i readjusted my idle back to stock, it hasnt been giving me that big of a problem anymore.
Old Jul 28, 2004 | 08:08 PM
cmrvi1's Avatar
Was it working correctly before you had the car shipped?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigSlim &raquo;</TD></TR><TR><TD CLASS="quote">now when I remote start it, it keeps cutting off after 3 unsucessful tries. </TD></TR></TABLE>
Can you elaborate a little more? During those 3 tries, does the engine not start at all, or does it start and then stall?
Old Jul 28, 2004 | 09:58 PM
BigSlim's Avatar
Default Re: Remote start problems (cmrvi1)
It worked fine before i had it shipped. It starts all 3 times runs for about 3-4 sec and cuts off.
Old Jul 29, 2004 | 03:35 PM
cmrvi1's Avatar
Your car is equipped with an immobilizer system, and it sounds like the immobilizer is cutting the engine off. The way the immobilizer works is as follows:
Each one of your keys has a transponder that the PCM is programmed to recognize. Even if someone was to copy on of your keys, unless it's programmed into the PCM, the engine won't stay running when you start the car with it. Just like what it's doing now with the remote start.
When a remote start is installed in a car with the immobilizer system, it requires an add-on module that copies the transponder code from your key. Everytime you use the remote start, the module sends the copied digital signal to the PCM. Once the PCM recognizes this signal, the engine will stay running. If the module was removed, or otherwise lost the immobilizer code, the PCM will view any attempt to remote start the engine as an illegal start and cut off power to the fuel pump.
You will need to get a manual for your particular alarm to first: identify the module, and second: to reprogram it if it lost the code.
Old Jul 29, 2004 | 07:11 PM
Accord02's Avatar
Um, could be a loose or bad tach wire.
Old Jul 29, 2004 | 10:13 PM
dougieb3's Avatar
its the tac wire. If I am understanding the immobilizer did not start until 98. I believe it is bad tach or needs be reprogrammed. Good Luck.
Old Jul 30, 2004 | 04:39 AM
KTeller8's Avatar
Default Re: Remote start problems (dougieb3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dougieb3 &raquo;</TD></TR><TR><TD CLASS="quote">its the tac wire. If I am understanding the immobilizer did not start until 98. I believe it is bad tach or needs be reprogrammed. Good Luck. </TD></TR></TABLE>
mine does it after my swap.. check also that all the wires are still intaact, starter, dizzy , etc
Old Jul 30, 2004 | 07:41 AM
philadd's Avatar
if it was the immobilizer system, the car wouldn't never start at all... It would crank and crank and crank, but never start.
SWE3TDUDE
Oct 6, 2012 06:29 AM
TurboTeG4
Acura TSX
Jan 12, 2012 07:37 PM
Xxcivic99xX
Audio / Security / Video
Nov 29, 2008 06:51 AM
boynblue
14
Dec 17, 2006 07:27 PM
Mike813
Apr 5, 2005 10:18 AM
