Recommended Alignment Correction
Old May 10, 2011 | 12:30 PM
Badbenz94's Avatar
Default Recommended Alignment Correction
Hello again!!
I have a 95 Accord Ex 2.2 Coupe and I am in the process of replacing all four upper control arms, doing the ROH conversion, and adding Tein S springs w Tokico struts based on recommendations here. Since I'm installing new arms, I don't want to go the ball joint replacement route and instead want to install the bolts front and rear. Since this is a daily driver, I want to keep the alignment close to specs. I see there are two different kinds of bolts for the front and something for the rear. Anyone w this setup set me in the right direction so I only have to do this once? Thanks!!
Old May 12, 2011 | 08:41 AM
Badbenz94's Avatar
Default Re: Recommended Alignment Correction
Bump
Old May 12, 2011 | 09:00 AM
TheMuffinMan's Avatar
He knows where you live!
Please just do a search....the topic of adjustable ball joints vs adjustable anchors has been discussed multiple times - one informative thread being created within the last month or so.
Alternatively do a search and just have the toe set to 0 and run with the camber you have.
Old May 12, 2011 | 10:20 AM
Badbenz94's Avatar
Tried doing a search and I found a ton of unrelated articles. If u have the link to the article above I would appreciate it. Thank!
Old May 12, 2011 | 10:28 AM
For the future, you need to do an Advanced Search and select the Accord subforum.....
https://honda-tech.com/forums/showth...ghlight=camber
Search for 'alignment' in the Accord section results in 10 pages (250 threads) of Accord posts regarding alignment.
Old May 12, 2011 | 10:30 AM
Badbenz94's Avatar
Thank you.
CosmicJ
Sep 14, 2017 11:59 AM
blackccoupe
Sep 7, 2009 07:18 AM
I AM WEASEL
Jan 10, 2008 06:58 AM
igo4bmx
14
Aug 5, 2004 01:20 PM
Buttcrack
Jan 22, 2004 08:37 AM
