Recirculation button doesn't work anymore
Old Dec 10, 2014 | 09:50 AM
Knightrider03m's Avatar
Default Recirculation button doesn't work anymore
i have a 93 Accord and my heating controls is stuck on the recirculation mode which means that when I drive my car, the windows fog up on me automatically. My question is this, where is the door to turn the recirculation mode on and off? I'm thinking if I can open it back up that I would be ok.
Old Dec 10, 2014 | 01:07 PM
professorman's Avatar
Default Re: Recirculation button doesn't work anymore
Do you turn the A/C on? The windows don't defog without the A/C.
Old Dec 10, 2014 | 03:11 PM
Lost Again's Avatar
AN old 4th gen, the ac might not be working - never came with it - and if not working the cost of repairs might be more than the op want to do.
OP - from the pass floor, look behind the glove box and see if you can locate the motor. Never had a 4th gen so not sure if the glove box has to come out to get to it? Here is a pic that I hope will help.
Old Dec 10, 2014 | 04:23 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Issue may be due to one of the following:
• Faulty heater control panel
• Faulty Recirculation motor
• Stuck door or linkage
1. You can see if the recirculation motor can switch to fresh air by applying 12 volt power (+) and ground (-). Unplug the 3-pin gray harness connector (Connector C439) to the motor. Apply battery power (+) to the Yel/Blk wire and body ground (-) to the Grn/Wht wire to see if the motor will now switch to Fresh air mode.
2. Otherwise, you can try to manually move the linkage.
Old Dec 12, 2014 | 04:46 PM
Thanks guys. I'll check on it when I get off from work this weekend.
vteclude217
Aug 15, 2009 08:21 AM
illumin72
Jul 10, 2006 10:43 PM
Captain Flaps
Apr 20, 2006 08:48 PM
trbob16a
Jun 4, 2002 09:37 PM
UTCiv
Nov 22, 2001 04:04 PM
