TURBO TIMER issue - will any obd1 harness work?
i have a 95 accord that i am about to install turbo timer onto and i would prefer to use a harness. problem is i have searched and cant seem to find one. just wondering if i can use an obd1 civic harness?
Re: TURBO TIMER issue - will any obd1 harness work? (hb_guy)
No you will need to hard wire it in. There really easy wire up. You need a couple of grounds, a tach signal, ower and the correct ign. wire. There are 2 make sure you test and get the correct one or the fans won't run and the car will over heat when its running on the turbo-timer.
Re: TURBO TIMER issue - will any obd1 harness work? (Turbowa)
k. thanks. guess i better search elsewhere cuz there isnt any info hardly in the archives here for the accords
Turbo timers are cool and all and they look cool. BUT, instead of getting aturbo timer why not just let your car idle for 30 secs to a min before you turn it off??? Thats what I do, its not any different.
