quick question
Old Mar 12, 2006 | 08:21 PM
soon2bdropped's Avatar
Default quick question
will 92 accord axle work on 94-97 accord? i got the axle from autozone.. just wondering.. because i got Lifetime warranty for 92 accord axle...
anyways when the tailpipe has water coming out of it constantly.. what does it mean? i mean water will come out whether car is cold or hot.. and also u can smell gas fuel from inside the car.. is killing me..
looks like the combustion is burning water instead of air and fuel gases lol
Old Mar 12, 2006 | 08:27 PM
P_Adams's Avatar
Default Re: quick question (soon2bdropped)
What's confusing the situation is:
One of the by-products of burning hydrocarbons is....... Water. The question is: How much?
If you aren't loosing coolant, it's not coming from anywhere other then burning gas.
P
Old Mar 12, 2006 | 08:35 PM
Default Re: quick question (P_Adams)
explain the losing coolant parts? and do u know the answer to the axle question? thanks
Old Mar 12, 2006 | 08:45 PM
P_Adams's Avatar
If you're loosing coolant, yet have seen none leaking; it's going somewhere. Hopefully it's the water pump (mounted under the timing belt covers), because if it's not the water pump (and you can't find a leak anywhere, you could have a leaking head gasket.
It (leaking head gasket) will be accompanied by specific symptoms. Heavy white acrid smoke from the exhaust and rough idling / dead cylinder.
Axle question: If they were compatible, the parts listing would read '90 thru '97 Accord DX.LX,SE and EX - but they don't. I suspect because the 5th Gens have a wider track, the axles are correspondingly longer.
P
sfar785
Dec 14, 2011 01:46 PM
forestcd6
Sep 9, 2010 08:22 AM
1baddcivicsi
Apr 24, 2006 07:33 PM
SmurfDA
Feb 22, 2004 04:28 PM
ih8danoles
Dec 14, 2003 10:45 AM
